Go to Post However, the best responses come with patience. It might be a couple of days before you get a good answer or it could be 10 minutes. - Molten [more]
Unread 18-02-2012, 14:50
davincirobotics davincirobotics is offline
FRC #4201
davincirobotics is an unknown quantity at this point
Kinect Holonomic Code
I am having trouble writing a kinect code for holonomic drive. For some reason when I run my code, nothing happens. Here is a link to the code that I have right now. Does anybody see any obvious problems with it? If you do please tell me.
Unread 18-02-2012, 16:26
Pirate programe's Avatar
Pirate programe Pirate programe is offline
FRC #0354
Pirate programe is an unknown quantity at this point
Re: Kinect Holonomic Code
The Refnum Get VI has no refnum attached to it.
Unread 18-02-2012, 19:00
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Tracked just means that the Kinect can see and distinguish that joint. This code is going to try to do a whole bunch of different things at once even if you solve the previously mentioned refnum issue.
As Greg McKaskle wisely posted in another thread, start with the English sentence of what you want the code to do and we may be able to point you in the right direction to get the code to do it.
Unread 18-02-2012, 21:11
FRC #4201
Basically I want the code to go forward when the right hand is raised, rotate when the left hand is raised, and move sideways either right or left based on which way the driver moves his/her hip. What should I use instead of the tracked block in order to tell it to do this?
