Go to Post REMEMBER - there ARE things more important than robots... false - Botwoon [more]
Unread 18-02-2012, 15:27
dan2915 dan2915 is offline
None #2915
dan2915 is an unknown quantity at this point
Can't connect SmartDashboard to Camera
Hello all,
We're having trouble connecting our SmartDashboard to our camera. We're using the WPICameraExtension and we're getting the following error:
Stream #0.0: Video: mjpeg, yuvj420p, 320x240, 25 fps, 25 tbr, 1200k tbn, 25 tbc
[swscaler @ 0473CE60] No accelerated colorspace conversion found from yuv420p to bgr24.
[mjpeg @ 04787920] max_analyze_duration reached
[mjpeg @ 04787920] Estimating duration from bitrate, this may be inaccurate
Input #0, mjpeg, from 'http://10.29.15.11/mjpg/video.mjpg':
Duration: N/A, bitrate: N/A
We have our camera setup for Anonymous viewing, and the weird thing is that if we wait long enough, it will sometimes connect. We have scoured ChiefDelphi and we have tried nearly everything.
We believe that the problem is with our copy of ffmpeg. Any suggestions? We can't display the raw image on the SmartDashboard but we can see it fine from the Axis Camera browser tool. Any help would be great, thank you!
