Go to Post If we can transform our culture to the point where girls swoon over guys as they pull their dremel off their belt and carve some speed holes in a smooth fluid motion, I think FIRST is half way to its goal. When we get the guys to swoon over the girls for their hot moves on the 5-axis, we have won. - EricVanWyk [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 18-02-2012, 15:52
beandip3160's Avatar
beandip3160 beandip3160 is offline
FRC #3160
beandip3160 is on a distinguished road
HELP Swerve Drive!!!!!
Ok I'm actually pretty new to labview and actually programming altogether and this year our team decided on using swerve drive for our robot. I am freaking out because we only have four days left and this drive system is a nightmare. Can somebody help me please. our main problem is getting the pod part of the wheels to act like a servo motor and follow the axis value of the controller we're using with a max turn of 90 degrees i have the encoder wired correctly and the encoder isnt a problem so how can i make the motor act as described above
Unread 18-02-2012, 16:36
nick1023 nick1023 is offline
FRC #1023
nick1023 will become famous soon enough
Re: HELP Swerve Drive!!!!!
Team 358 has graciously posted some labview code on their site here that has a PID example for swerve drive. This example uses a POT instead of encoders.
http://team358.org/files/programming...2009-/LabVIEW/
P(ID) example 2010.
1023 Bedford Express
Unread 18-02-2012, 17:06
FRC #3160
Well we were actually looking into pots right now and my main question is how the PID actually works. The lab view help doesn't exactly describe it in the terms of a newbie.
Unread 18-02-2012, 17:39
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
What part don't you understand?
Unread 18-02-2012, 17:57
FRC #3160
The help says that The PID range features control output raange limiting with integrator anti-windup and bumpless controller output for PID gain changes. Use the DBL instance of this VI to implement a single control loop. Use the DBL Array instance to implement parallel multi-loop control.
That is really a fantastic explanation and all plus you can tell national instruments wanted to explain it but what does it mean
Unread 18-02-2012, 17:59
Ether's Avatar
Rookie Year: 1969
One way to look at it is, PID turns your motor into a servo.
You know what angle you want your wheel to be at, and a sensor knows where the wheel actually is.
The first is called the setpoint, and the second is called the process variable.
You provide the setpoint and the process variable as inputs to the PID, and it takes care of the math to figure out what output to send to the motor to make it do what you want.
Armed with that overview, try reading these and see if they make any sense:
http://www.eetimes.com/ContentEETime...0/f-wescot.pdf
http://en.wikipedia.org/wiki/PID_controller
By the way, you guys should get a team member whose job it is to hang out on Chief Delphi and check things out as your team is making decisions. Had you done so, you'd have known that it is strongly advised that a team not attempt swerve for the first time during build season. I feel your pain.
Unread 18-02-2012, 18:34
FRC #3160
Well we are actually a third year team; however this is My first year actually programming the robot our old programmer is going to college and isnt around all the time to help out .
Thanks though for the information and the pdf file i am going to use what i now know with team 358's example you've been a big help
Unread 18-02-2012, 18:37
Ether's Avatar
Rookie Year: 1969
That's not what I said. It doesn't matter if it's the team's 10th year. The question is, has the team ever done swerve before; and if so, has the knowledge gained from doing so carried forward to this year's team?
Unread 18-02-2012, 18:45
FRC #3160
Thats what i told everyone when we started doing this that the swerve drive would be a good summer project i was against doing it as our programming has been simplified before so that we wouldnt need many sensors however they seemed to think it would be a good idea to try it this year
Unread 18-02-2012, 18:47
Ether's Avatar
Rookie Year: 1969
Hey, look on the bright side. Every cloud has a silver lining: think how much you'll learn.
Unread 18-02-2012, 18:49
FRC #3160
my thoughts exactly because of swerve ive done work with encoders and potentiometers now
