Go to Post I still have 3 good ligaments left and 2 events, so I should be fine :rolleyes: - esquared [more]
Unread 18-02-2012, 15:59
Team1168 Team1168 is offline
FRC #1168
Team1168 is an unknown quantity at this point
Is this design legal?
It's kind of late for this, but we were wondering if the arm we've designed is legal. It's a protuding arm that swings open at the beginning of the match and stays open for its duration. Would this cause problems with inspection?
Unread 18-02-2012, 16:09
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
Rookie Year: 2011
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Re: Is this design legal?
Pictures would be nice if possible.
As long as your arm is 1 appendage and extends less then 14"" outside your frame perimeter you should be fine. Can't get any more exact with out drawings or pictures.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 18-02-2012, 16:10
Rogue Leader Rogue Leader is offline
FRC #0696 (Circuit Breakers)
Rookie Year: 2011
Rogue Leader is an unknown quantity at this point
It should be legal, so long as it only protrudes 14in. or less from the edge of your frame and you don't use it to harm other 'bots. Make sure it's completely tucked in at the beginning of the match too. But you're being a bit vague as to what it actually is or looks like, so this is the best advice I can offer.
