Go to Post One of these years, the game piece will be an actual red herring. - Taylor [more]
Unread 20-02-2012, 17:19
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Re: Runaway CIM motors
Originally Posted by Al Skierkiewicz View Post
Did a limit switch jumper on the Jaguar fall out? It is possible that the Jag is trying to get back from a limit condition.
I've never used a Jaguar with limit switches, but I'm confused how this could happen. The switches are supposed to be wired normally-closed, so if a jumper came out the Jaguar would act as if the switch had been pressed. The Jaguar datasheet specifically says that the motor stops when a switch is pressed. Am I missing something?
Originally Posted by Jaguar datasheet
Two limit switch inputs provide a method for immediate shut-down of the motor. The inputs expect typically-closed contacts - one for each direction of rotation.
http://www.ti.com/litv/pdf/spmu064c
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 20-02-2012, 10:33
BullBot Mentor's Avatar
BullBot Mentor BullBot Mentor is offline
FRC #4368
Rookie Year: 2012
BullBot Mentor is an unknown quantity at this point
Originally Posted by slijin View Post
Immediately check your robot for a chassis short.
Although Jaguars are a point of failure, applying 12V across drive motors will spin them, no matter where the source. Albeit unlikely, make sure that this is not the case.
Thank you for the tip. We did stop and check all connections to make sure we were not shorting anywhere and everything looked good. We will check again when we meet up this evening.
Unread 20-02-2012, 15:17
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
Rookie Year: 2012
shuhao is an unknown quantity at this point
See if you flipped the input with the output on the jags. We (i) did that and fried 2 jagur
