Go to Post Consider how nature does this, and emulate. Nature usually has a pretty good algorithm. - DonRotolo [more]
Unread 18-02-2012, 22:17
CompSciGeek CompSciGeek is offline
FRC #0948
CompSciGeek is an unknown quantity at this point
Any ideas for what we can do?
So.. our team is in the tightest spot we've been in for years. Mechanical has STILL not finished with the robot and electrical still has to wire stuff! And theres 3 days left! Programming has not even tested one bit of our code. We don't know if anything works.
We've pretty much finished all our classes and methods.
We're already probably not going to a joint practice field, but is there something programming could be doing while waiting thats really productive besides playing Minecraft?
Unread 18-02-2012, 22:25
rockytheworm's Avatar
rockytheworm rockytheworm is offline
AKA: Chris Kirk
FRC #1517 (Lumberjacks)
Rookie Year: 2011
rockytheworm is an unknown quantity at this point
Re: Any ideas for what we can do?
Its a little late for this but you could build a test board if you have a spare crio, digital sidecar, and fuseboard. If you could build one you could test out your sensors and small chunks of your code. If you have a similar robot from a previous year lying around you could work with that as well. Like I said, its a little late but every bit of productivity counts.
ianonavy ianonavy is offline
Programming Mentor/Alumnus
AKA: Ian Adam Naval
FRC #3120 (RoboKnights)
ianonavy is an unknown quantity at this point
If you've got extra control parts, you could throw together a test bed and make sure the correct jaguar lights are turning on when you power it all up. My team built a separate simple chassis that just drives with a camera so I could work on vision tracking code while they built the actual robot.
Unread 18-02-2012, 22:36
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
Don't panic. Yesterday our robot left for a scrimmage at 5pm with ZERO electronics because we wanted to finish mechanical so no metal got in the electronics. By the end of last night around 10:30 we were 95% wired and ready to go after an hour the next morning.
Steps to help!
Get EVERYTHING laid out. Every wire, every jaguar, every solenoid, make sure you have EVERYTHING including connectors, and make sure everything is updated and ready to go!
Have a general idea of where things go and once mechanical is done, lay EVERYTHING out on the robot and start attaching. We grabbed mechical guys including myself to attach electronics while the electrical guys made wires, directed, and attached everything.
If you need anything mechanical: battery box, extra levels, attachment points, etc get them done now by mechanical.
Essentially have everything done and ready to go and check your list twice or three times! We got held up as we forgot a few items but we stayed focused and on task! Most importantly don't get flustered or angry, work together. I know it sounds cheesy but week 7 brings out the worst sides of people.
Whats more important? Getting it done right or getting metal shavings in a sidecar and dying in a match? Its a horrible reality when it happens.
After about 6 hours of wiring and debugging we got all this done!
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
