Go to Post Man, Dave always has to one up us. We build robots to play games, he build robots to go on other planets, Elgin makes CD 30 inches, you make it 63 inches. - Levin571 [more]
Unread 18-02-2012, 22:42
Hebrew Hebrew is offline
FRC #4228 (iRobotics)
Rookie Year: 2012
Hebrew is an unknown quantity at this point
Autonomous
Hi there!
I am a rookie programmer (The only one actually) and I am wondering if anyone could give me a bit of help in getting an autonomous program working. First you should know a bit about our robot:
  • We are using a tank drive with the standard wheels given in the KOP
  • We have 4 wheels powered by 2 motors, so 1 motor controls both wheels on each side.
  • We are using the standard frame given in the KOP
  • On the back of our robot is an 'arm'. It is used to lower the bridge.
So, I had a bit of fun playing with autonomous mode the other day, I got the robot to spin a bit. The problem is, I have absolutely NO idea how to specify speeds or how to activate a piston in autonomous. I have 2 days so I REALLY do not want to play with it much, I just want a bit of help getting it done. Could someone give me an example on how to get the robot to move straight for X amount of time/distance and then after that is complete activate a piston?
Thank you very much.
EDIT: I got the robot to move forward, I still cannot get the piston to fire at the correct time.
Unread 19-02-2012, 09:11
Re: Autonomous
The template code autonomous function had some for loops and robot drive functions disabled. You can right click on them and enable or remove the disable structure.
To time how long it has been since autonomous started, take the time at the beginning, take the time after some other operation and subtract and compare to your trigger point.
Greg McKaskle
Unread 19-02-2012, 11:13
Rookie Year: 2012
Re: Autonomous
I'm pretty sure I just do not know how to activate the solenoid in autonomous. I have been using 'WPI_SolenoidSet.vi' inside a while loop....I want it to activate and stay activated until the end of autonomous...how is that possible?
Unread 19-02-2012, 12:13
Re: Autonomous
As long as the Safety mechanism hasn't been turned on, the solenoid will stay on set until you turn it off. When the robot is disabled, the solenoids will also be disabled, but will return when enabled.
What symptoms are you seeing?
Greg McKaskle
Unread 19-02-2012, 18:35
Rookie Year: 2012
Re: Autonomous
So before I was using a while loop but now decided to switch it up to make it easier...now all our robot does is have the wheels move for a split second and then it shoots the piston. What am I doing wrong?
Unread 19-02-2012, 20:30
Re: Autonomous
You don't explain what the robot does or doesn't do. I'll transcribe what I'd expect that to do.
It sets the RobotDrive to 0.5, which is normally backwards pretty fast. It leaves it set that way for ten seconds. Then it kills power to the RobotDrive and lets it coast/brake for four seconds. Then it sets the relay to forward.
Issues/Questions:
Unless your normal teleop negates the joystick values that it sends to the RobotDrive, this looks like it will drive backwards.
Unless your turn off the Safety Mechanism for RobotDrive, after 100ms, the motors will be disabled. If you develop carefully and want to disable it, you can do so from the Advanced palette of RobotDrive.
Greg McKaskle
Unread 19-02-2012, 20:50
Rookie Year: 2012
Re: Autonomous
Driving backwards is the goal for how the robot drive is currently set up. I entered random numbers for the time each task is done just to make sure it follows it, I know that I have the values up VERY high currently.
Thanks for the info on why it is stopping though! I am not with the robot right now so I cannot experiment for myself so I am wondering: What .vi do I place instead of the current drive vi? I am confused as to what I am exactly doing for it to not shut off in 100ms. Another issue: It does not usually wait 4 seconds like I have it set to before the piston is fired, do I have to do something there or was the immediate stopping of the motors causing it to speed up or something?
Unread 19-02-2012, 22:31
MAldridge's Avatar
MAldridge MAldridge is offline
Lead Programmer
AKA: Rube #1
FRC #0418 (LASA Robotics)
Rookie Year: 2010
MAldridge will become famous soon enoughMAldridge will become famous soon enough
Re: Autonomous
you don't need to replace it, but you need to disable the safety threads on those motors. To do that, go to robot drive and then hit the advanced functions button, there you will find the safety config VI.
You just need to connect it in front of the actual drive VI that sets the output. Make sure you have the robot on blocks until you know EXACTLY what you are doing with the autonomous. Once you disable the safety, the robot will move until you tell it to stop.
Good Luck.
'Why are you a programer?' --Team Captain
'Because the robot isn't complicated enough!' --Me
Unread 20-02-2012, 08:00
Re: Autonomous
Please do start with it on blocks, but to be clear, eStop still works and cannot be disabled. Safety Config disabling is specific to the update heartbeat.
Greg McKaskle
