Go to Post the golden rule of robotics for the 21st century: Do unto robots as you would have them do unto you - KenWittlief [more]
Unread 18-02-2012, 23:23
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Team Role: Coach
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Turning with 4WD / Pneumatic Tires / Wide Config
Our team is running a wide configuration 4WD with 8" AndyMark pneumatic wheels. It has a 15" wheelbase and a 32" trackwidth. It is geared for about 5 and 12 ft/s. Tires are fully inflated.
It skips and jumps when it turns. We can still get around just fine, and maybe we will smooth out the turning one way or another. But my main question is should we have seen this coming? I had assumed that it would turn well with a wheel base that was twice as wide as it is long.
Last edited by Nemo : 18-02-2012 at 23:30. Reason: Fixed terminology after Ether's post.
