Go to Post :( The Internet just ate my post. - Greg Marra [more]
Unread 19-02-2012, 11:13
jwatson12 jwatson12 is offline
Mr. Watson
FRC #1025 (Impi Warriors)
jwatson12 is an unknown quantity at this point
Locking out actions based on a button press (without using variables)
Hi All:
We have a programming puzzle where we would like to lock out certain functions when a button is pressed. For example, when opening a solenoid by pressing button 5, motor actuation assigned to axis 2 of joystick 2 (for speed control) is disabled until a different button is pressed. Then, once button 7 is pressed, control is restored. Our current solution is to use a case statement assigned to button 5 that when true sets the solenoid and then a while loop is called within the Case structure until interrupted by Button 7. The exit tunnel of the case structure then continues the opposite solenoid action.
Can someone take a look at this and tell me if this is on the right track or is there a better way?
Thanks!
Name:	Press Button five.png
ID:	11987  Click image for larger version
Name:	Press Button seven.png
Unread 19-02-2012, 18:55
Wildcats1378 Wildcats1378 is offline
Rookie Year: 2011
Wildcats1378 is an unknown quantity at this point
Re: Locking out actions based on a button press (without using variables)
Check out the The Joystick Button Latching.vi example in Help -> Find Examples. That shows you how to use features which toggle.
Otherwise, you're on the right track!
