Go to Post The jags are powered with magic... - Aren Siekmeier [more]
Unread 19-02-2012, 13:29
quinxorin quinxorin is offline
Mentor now :(
AKA: Ian Pudney
FRC #0862 (Lightning Robotics)
quinxorin will become famous soon enough
A Story of Victor, and him not connecting
This year, our team decided to use Victors instead of Jaguars for the first time since 2008. It's been trouble.
Yesterday, we were having motor signal issues. Some victors would start receiving signal, then stop, then start again. Eventually, we managed to make them all stop working. After three and a half hours, we finally figured it out - the PWM cables have to be put into the victor exactly right, or one of the pins misses and doesn't connect.
Mentors don't seem to remember having all this trouble back in The Olden Days, so what's up? Have the tolerances on the Victors changed, does it have to do with the fact that we make our own PWM cables whereas back then we most likely bought them, or are we doing something terribly wrong?
"Sed res docuit id verum esse, quod in carminibus Appius ait, fabrum esse suae quemque fortunae."
- Every man is the architect of his own fortune.
Unread 19-02-2012, 20:11
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: A Story of Victor, and him not connecting
Victor PWM connections have always been finicky in my experience (since 2004). It's probably just that people are out of practice now, after having used Jaguars for a while.
Unread 23-03-2012, 13:29
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
Team Role: Coach
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Adding to what Alan has said is that there appears to be 3 wire PWM cables that have an extra tab along one part of the connector (keying feature?). This key increases the size and makes it more difficult, if not impossible, to insert into the PMW connector housing on a Victor. I found this issue while changing PMW cables at the Waterford MI district tournament.
BTW, I use a paint pen (better than hot, sliced bread!) to whiten the side of the PWM connector housing corresponding to the white PWM signal wire. This helps everyone to remember the correct physical orientation of the PWM cable. I recommend this practice for everyone.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 23-03-2012, 14:18
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
As previously stated, Victor PWM sockets are notoriously difficult to properly seat the PWM cable in to. Once the connection is made, a small application of Hot Glue to the connector will aid in them staying in place. (Small, as in the size of a BB or 4mm sphere.) Additionally, it is removable and quick setting.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 23-03-2012, 18:11
DavisC DavisC is offline
FRC #0539 (Titans)
Rookie Year: 2010
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
not sure if it always works (we have some quite messed up PWM wires at our place) but my general rule of thumb is that the metal side (the side of the connector housing with it showing) should be so that it faces inward (toward the center of the Victor).
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
