Go to Post I see you've one-upped me in the stripped gear game. I commend you. - frcguy [more]
Unread 19-02-2012, 16:40
mrcj mrcj is offline
FRC #3734
Rookie Year: 2011
mrcj is an unknown quantity at this point
wiring air compressor into cRIO
The air compressor and a regulator are currently hard wired and we know that's against regulations. How could I hook up the standard kop 90 viair air compressor into the computer? It says it's 40amp and we only have 20amp spike relays. Is there a special relay?
Unread 19-02-2012, 16:46
Chickenonastick's Avatar
Chickenonastick Chickenonastick is offline
Not a kebab
FRC #3256 (WarriorBorgs)
Rookie Year: 2010
Chickenonastick is on a distinguished road
Re: wiring air compressor into cRIO
I'm not too sure what you mean by hooking up to the computer, but a Spike relay, which comes in the KOP, would be the appropriate device to use to control the compressor.
Unread 19-02-2012, 16:59
FRC #3734
Rookie Year: 2011
Will 20 amps work for the Spike relay?
Unread 19-02-2012, 20:27
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
Yes, put the spike on a 20 A breaker to run the compressor and you are encouraged to replace the fuse in the spike with another auto-reset breaker.
Brian K
Team 1225 Robotics Mentor
Unread 19-02-2012, 20:31
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Not sure where you got 40A from. The current draw listed on the VIAIR website is 10 Amps:
http://www.viaircorp.com/OnRoad/90C.html
