Go to Post Look at the success of the Banebot's gearboxes this year. Cheap, light, small, and a lot of people are using them, even though their quality may be a bit questionable... Make a similar gearbox for a drivetrain (with a bit more robustness) and I think you've got a winner. - Ben Piecuch [more]
Unread 19-02-2012, 18:25
dcarswell's Avatar
dcarswell dcarswell is offline
FRC Mentor/Old Dominion University
AKA: DeAndre Carswell
FRC #3359 (Royal Robotics)
dcarswell is an unknown quantity at this point
Left Motor..Jaguar Keeps Going Out-Is it Programming ?
Hi,
Our team was working on the programming today and suddenly the left side drive motor wouldn't work. But the right side did. So then we went to look at the jaguar and the jaguar was blinking red, we turned the robot off then on again, and the jaguar was back on..and then all of a sudden the jaguar didn't even have a light on it ? Is this something wrong with the programming or the electronics ? Like I said the right side works, and they both work like 1 out of 10 times together...and then after that the left side goes out again..Were using the basic arcade drive..
Thank you..
Unread 19-02-2012, 18:43
Wildcats1378 Wildcats1378 is offline
Rookie Year: 2011
Wildcats1378 is an unknown quantity at this point
Re: Left Motor..Jaguar Keeps Going Out-Is it Programming ?
The Jaguars come with thermal protectors, that shut it off when it gets too hot; like a thermostat. Perhaps you should let it cool down?
If it doesn't light up again after some time, it possibly means it was burnt out, which has happened to us.
Unread 19-02-2012, 18:54
dcarswell's Avatar
So is it common for the jaguars to burn out ?
Unread 19-02-2012, 18:58
Rookie Year: 2011
Depends on electrical wiring, how long you run it, etc.
