Go to Post I'm so conflicted right now. On one hand, you made the same page as a celebrity. On the other hand.... Justin Bieber. - Akash Rastogi [more]
Unread 19-02-2012, 21:14
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Resizing Dashboard and DS?
Hello -
At the Suffield Shakedown, I noticed that when logged onto the Driver account of our Driver's computer (Lenovo Thinkpad), the DS and Dashboard auto-resized themselves to fit the Classmate screen.
Are we allowed to compile a version of the Dashboard to fit a larger screen, and if so, how? I've tried compiling a version, however it resizes and appears terribly askew. Is there a way, at least, to stop them from snapping to the side of our screen?
Thanks.
Unread 19-02-2012, 22:05
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Resizing Dashboard and DS?
You can do what you want with the Dashboard.
Look at the bottom of Dashboard Main.vi and you'll see where it gets sized and positioned on the screen if the user account= Driver (you can change that, too).
Before you save the Dashboard and create the executable, size it and position the front panel to make it look like you want.
At the very, very bottom flags are set to make it NOT closable, minimizable, and to remove the window title bar.
Unread 20-02-2012, 06:38
FRC #0023 (PNTA)
Rookie Year: 1620
Awesome, thanks! I assume we'll have to live with the DS, right?
Unread 20-02-2012, 07:13
Just Itinerant
The DS can't be reworked, like the Dashboard can.
It can be moved around to reposition it on the screen if the user account isn't Driver. The Driver account is optional during competition this year, not like last year. The Driver Station application does give you the option to fix it in it's standard position in other user accounts, too.
The only way to make it larger is by changing screen resolution.
Unread 20-02-2012, 18:45
FRC #0023 (PNTA)
Rookie Year: 1620
So FRC officials won't be perturbed if I am not using an account named "Driver", correct?
Unread 20-02-2012, 19:57
No. The field won't care, so the officials don't either.
Greg McKaskle
Unread 20-02-2012, 20:01
FRC #0023 (PNTA)
Rookie Year: 1620
I assumed the field had no feelings because it failed to bite back at our bot after I cursed the scrimmage field in CT for getting balls lodged under the bridges...
Thanks, makes things a bit easier.
