Potential DSC Damage
As I can't find this specification on the USFIRST-provided spec sheet (or a confirmation through forum searches), I'm turning to the CD community for a definitive answer to this question: Is the ground on the GPIO pins of the DSC 12V tolerant? Alternatively, will plugging in a 12V signal to the power or ground pins on the GPIO damage the DSC?
The reason I ask is because we've been having issues with an apparent short to our frame, which induces sudden motion upon providing power to the robot, but the short point is unidentifiable, and we suspect the damage lies in the DSC. The current situation is as follows: Closing the circuit breaker (giving power to the PDB) will, on occasion, incur forward motion in a number of motors that persists for a few seconds. I know for sure that the motors on PWMs 1-3 and 6-7 are moving forwards; 4 and 8-10 have no connections, and 5 may be doing so (but is unconfirmed). Later testing only saw motion in a subset of these motors (which is undetermined). The backstory: The sensors (details later in the post) were wired with +12V and GND to a 20A PDB, a 1K pullup across the 5V and signal, and the signal wire was mistakenly plugged into both the +5V and GND (at two different points). The one common factor that we have confirmed is that this phenomenon only occurs when the signal from our conveyor sensors is plugged into the DSC (on the signal pins), in particular when one of them is activated. We are using Banner QS18VN6D sensors (the white signal line) for this purpose. The camera and cRIO are isolated from the frame and we cannot identify any other potential shorting point. Edit: Omitted detail: All 3 lights on the DSC are lit. The RSL has yet to be connected, so I can't describe its behavior. We didn't get a chance today, but we plan to confirm tomorrow whether the point of failure is the DSC (if we can reproduce the issue) by cutting its power and unplugging the DB37. Until then, it would be great if someone could confirm our hypothesis. Last edited by slijin : 20-02-2012 at 00:32. |
