Go to Post A wise man told me a few nights ago, that it is important to own up to all your mistakes, so that others can see you doing that and wont deny and try to hide their own. - Josh Hambright [more]
Unread 19-02-2012, 23:03
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
Fisher Price Overheating Troubles
We have been using two Fisher Price motors on our shooter, using a combination of an AM planetary and sprockets to gear the motor down and then up again. The final ratio is about 1.8:1 (reduction).
We are using the 0673 Fisher Price motors (the ones with the wattage similar to a CIM), and have been having lots of problems with overheating. We are getting mediocre performance from the shooter (about 13 feet), and have already fried at least one motor. Overheating really the problem, in my mind. We are running a motor that has much less thermal mass than a CIM around the CIM's wattage. To me, its no wonder it is overheating.
Some more data: we were using an optical tachometer (the type used to measure the speed of a model airplane prop) and getting a speed spinning freely of about 4800 rpm. The motor is drawing about 37 amps accelerating and 27 steady state.
To me, these numbers show that our setup is very inefficiency, and we could significantly reduce our overheating issues by using a more efficient reduction. What is a good solution to our overheating/inefficiency problem?
Unread 19-02-2012, 23:09
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Fisher Price Overheating Troubles
How did you measure the amps?
What is the diameter of your shooting wheel(s)?
What is the design of your shooter:
- top and bottom powered wheel(s)?
- top and bottom wheel(s), only bottom powered?
- bottom wheel(s) (powered) and chute on top?
- something else?
The free speed and current you quoted above (4800rpm & 27amps) - was that at 100% PWM?
EDIT:
4800rpm * 1.8 = 8640 rpm motor speed
from the motor curves, an 0673 drawing 27 amps at 8640 rpm is getting only about 8 volts.
So, you are gearing your speed up and then dropping the voltage down.
I suggest that you get rid of that second-stage gear-up and run this thing with a net gear-down ratio of 4:1 instead of 1.8:1
Unread 19-02-2012, 23:23
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
I will hazard a guess without having all the information that you are running WAY too high a gear ratio.
I helped another team set up a shooter to shoot from mid court with 6 inch wheels and 2 banebots 775 (13000 rpm free speed). Their gear ratio once we did the math is around 2.5:1.
FP's run around 18000 rpm. Which means to run the same setup, you should be running around 6:1 or 7:1. You've overheating because you're on the wrong side of the motor curve, and are stalling the motors.
Fisher price are incredible motors, as long as you run them at high speed so their fan can cool them off a bit. That means a high gear ratio.
Cims are bulletproof and can be abused. FP's take a bit more math and finesse.
Unread 19-02-2012, 23:26
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Make sure you aren't blocking any vents on the motors. I don't know about the 673s, but similar motors have vents on the same side as the output shaft that are supposed to draw "cool" air over the electrical elements and out the back. Installing the motor in a gearbox will most likely block the vents. There is a thread describing how a team modified their gearbox to allow for cool air to enter at the vents.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
I would suggest a higher reduction, really. We're using the CIM-sim to direct drive 6" wheels and getting plenty of distance with our shooter. I think this is a case where less is more.
As far as increasing the distance of your shooter, it's hard to say without seeing your set up. You could have too little compression on the ball, so you're not transferring much energy to the ball. This is probably true if your wheels don't slow down much after firing. You could have too much compression. If your wheels slow down a LOT, this could be why.
You might have too little engagement time with the ball if the wheels don't slow down much. Or too much time if the wheels slow down a lot.
And then there's the angle you're firing at, and a dozen other variables, I'm sure.
Unread 19-02-2012, 23:27
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Rookie Year: 2010
We are using two belts, one on either side of the ball. The lower of the two rollers has a pitch diameter of 3.14in, the upper, around 1.69. As for the measured current, that was told to me by the programmers (I really just do mechanical stuff), I suspect off the dashboard. The motors are run by Jaguars with CANBus, and were run a 100% to get that speed and current.
Your suggestion about removing the second stage is interesting. If I was unclear before, we are getting that ratio with sprockets, so a 1:1 set up would be very possible. You are essentially saying that our motors are having trouble because they have too much load? It seems like that would improve overheating, although at the cost of range.
Unread 19-02-2012, 23:28
Ether's Avatar
Rookie Year: 1969
He provided enough information* (motor speed and amps) to determine that he is running the motors at about 8 volts. So they are gearing the motors UP and then lowering the voltage. I suggested they get rid of the gear-up portion and try that.
* assuming the given data was correct
Unread 19-02-2012, 23:31
Ether's Avatar
Rookie Year: 1969
The motors are operating at a very unhappy torque & speed point.
If you get rid of the gear-up you can increase the motor voltage to get the same wheel speed at a faster motor speed which puts the motors at a much happier operating point.
Motors don't like to go slow. They want to go fast.
Unread 20-02-2012, 00:38
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Rookie Year: 2010
What do you mean by running them at a different voltage? As I understand it, the current changes when more or less power is given to the motor, not the voltage.
Also, changing the ratio to be greater will make the motors run faster, not slower, to run the outputs at the same speed. I'm not quite sure why changing the gearing would change the motor speed. As I understand it, it would just make the belts spin slower. This would give them more torque, but the motors are overheating even without feeding balls through.
Unread 20-02-2012, 01:27
G33K's Avatar
G33K G33K is offline
Professional Baller
AKA: Ethan Anderson
Team Role: Electrical
Rookie Year: 2010
G33K is on a distinguished road
I think what is being said is that as you draw current from the battery, its voltage drops and decreases the speed of the motor further. If you run a lower gear ratio to get lower theoretical free speed on the belt, you may find that the lower current draw on the motor results in less voltage drop and therefore higher speed at the belt when all is said and done. Correct me if I'm wrong, though.
Unread 20-02-2012, 09:27
Ether's Avatar
Rookie Year: 1969
The command that you send to the Jaguar (or Victor) changes the duty cycle of the Jag's (or Vic's) PWM output, and thus changes the voltage being applied to the motor.
IF the data you posted is correct (4800rpm wheel speed, 1.8:1 gear ratio, 0673 motor drawing 27 amps), then you can use the motor curves to calculate the voltage the motor is getting. I explained this in post#2 in this thread. The answer was about 8 volts for the data you gave.
If you increase your gear-down ratio from 1.8:1 to 4:1 as I suggested, your motor will spin faster and your wheel will spin slower. You can then increase the voltage up from 8 volts to bring the wheel speed back up to where you want it. Your motor will now be spinning much faster than it was before, and with less torque load, and it will be much happier.
Unread 20-02-2012, 09:38
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
We are using those motors at 6:1 (ganged with some AndyMark motors running at 4.64:1) to a 8" wheel, the ball is going 24' or so and the motors running cool. We are thinking we were a little conservative and and might try 4:1.
Fast, cheap or working - pick any two!
Unread 21-02-2012, 00:33
skistunts1's Avatar
skistunts1 skistunts1 is offline
AKA: Jake Salzman
skistunts1 is an unknown quantity at this point
On behalf of DampRobot's team (Team 100), thank you for that suggestion. we tried that and it ended up working great. The motors are much happier now, and our shooter is going at least as far as it was before.
team100.org
Unread 21-02-2012, 01:03
Ether's Avatar
Rookie Year: 1969
That's good news. I'm glad I was able to help.
