Go to Post *referring to Team Titanium's 2012 robot* If only it could play guitar hero at the same time. sigh. - rsisk [more]
Unread 19-02-2012, 23:30
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
Digital side car power
I just want to give a heads up on a problem with a digital side car we had today. We have 3 Sharp IR sensors connected to the digital IO's. We were getting unstable readings from them. Before we had monitored them with a separate micro controller board and they worked fine. We found that we had to add a 100 uf cap across ground and 5+ to get a stable voltage to them. If other teams are having stability problems with the DIO and every thing else is right then the problem may be with the power. Try a cap. We had a similar problem with one analog break out last year.
Unread 20-02-2012, 09:38
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Digital side car power
Gary,
This is highly unusual. The 5 volt supply on the DSC is capable of several amps. It sounds like you might have a loose wire in the 12 volt line feeding the DSC.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 20-02-2012, 10:11
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Al, in my experience the Sharp IR sensors (though my experience was with the analog variety) are very sensitive to line noise on the 5V rail. The switching supply used in the DSC probably has enough output ripple to cause headaches for those particular sensors.
Unread 20-02-2012, 10:28
Unsung FIRST Hero
Rookie Year: 1996
The 5 volt supply has a 330mfd cap across the output.
Al
WB9UVJ
www.wildstang.org
Unread 20-02-2012, 10:36
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
A filter and a bypass cap VERY close to the sensor will do the most good.
Fast, cheap or working - pick any two!
