Go to Post "I'm not going to tell you all that you all are winners. At this point you are smart enough to know whether you are or you aren't." -Woodie Flowers - Barry Bonzack [more]
Unread 19-02-2012, 23:37
Wildcat Robotic Wildcat Robotic is offline
FRC #3039
Wildcat Robotic is an unknown quantity at this point
Question PS3 Controller Configuration?
Hope this season has been going well for everybody!
We are struggling with the configuration of the PS3 controller in LabVIEW. Can anyone help us with setting up a PS3 controller, give us some kind of instruction from A-Z: from how to set it up with the DriverStation to mapping out all the buttons and axes?
Unread 20-02-2012, 01:11
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: PS3 Controller Configuration?
In Teleop, Create -> Indicator for both the Axes and Buttons from any joystick you have in there. You'll just be borrowing it temporarily for a test.
Plug in the PS3 and user the Driver Station Setup Tab to move it to the joystick USB you borrowed in Teleop.
Run the LabVIEW project in debug from Robot Main.vi.
Enable the robot from the Driver Station.
Go to the Teleop front panel and watch the Axes & Buttons indicators as you manipulate each joystick and button on the PS3.
Unread 20-02-2012, 01:22
FRC #3039
Thank you! But can you explain it a little more detailed how to map the buttons and axes? I'm a little lost on this subject since it's the first year we are doing something like this.
Unread 20-02-2012, 20:14
Rogue Leader Rogue Leader is offline
FRC #0696 (Circuit Breakers)
Rookie Year: 2011
Rogue Leader is an unknown quantity at this point
Here's an example. You can ask me for help if the diagram doesn't help you.
Name:	LabVIEW Tutorial 3 copy.jpg
Unread 20-02-2012, 20:47
beandip3160's Avatar
beandip3160 beandip3160 is offline
FRC #3160
beandip3160 is on a distinguished road
You can also right click the controller while under devices and printers go to game controller settings and click properties you can calibrate and see which buttons are where here
