Go to Post Don't let the teams here be so much of an intimidation to you, but instead, an inspiration. They all had to start from the beginning, too. - Amanda Morrison [more]
Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Unread 20-02-2012, 09:56
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
Rookie Year: 2012
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
PD Board Legality Question
So one of our students broke the screw terminal thing on the Negative side of the PD board yesterday where it connects to the battery. There is only a small amount of thread remaining. (not enough to mount the ring connector and nut at the same time. So we welded to nuts together to create a threaded sleeve, which we can attach to the remaining nub. We then screw in a short bolt to the top of this sleeve to hold the ring connector from the battery. My question is: Will this pass inspection? Ideally we dont want to spend ~$200 on a new PD board.
