Team 73 Defensive Bot (Almost There)
Here's a pic of our 2012 bot. It is almost done, we just have to install chain on one of the wheels, add a kill switch, and a curtain to the front of the bot to help us retain balls.
Our team builds two different bots every year one offensive, one defensive to see which one is better. We haven't decided which one we are going to use. This bot is a blocker bot so it means we will be trying to stay in front of teams that will be shooting from low to the ground and attempting to catch their balls. We can also catch rebounds as we have an open top. We have an on-board shooter so it means we will be able to catch balls and shoot them across the field for our alliance members to pic up and shoot. We started working on this bot about 10 days ago. Tell me what you think? ![]() |
Re: Team 73 Defensive Bot (Almost There)
Personally, I don't like mecanums.
But besides that...my god is this a good idea for a robot. Without even seeing your other bot, I'd say go with this one. There are gonna be a lot of shooter bots that are only accurate from the key that need to be fed, and you gotta feed em! If you don't seed first with this robot, there is a good chance you will be pick #1. Last edited by Squeakypig : 02-20-2012 at 03:02 PM. |
Mecanums on defense? It does not seem ideal to me. Other than that, it is a very nice defensive design. I like it very much.
Our strategy is not push people around but to stay in front of them or just get on the opposing team's nerves. So the mechanums will give us manueverability to do that.
I agree with 73 in the fact that mechanums are actually a good idea for this defensive robot. As we've seen in the past, typical brute force FIRST defense doesn't always work out too well with safe zones. There will be a time and (very few) places for the brute strength to be brought out. I think for this "goaltending" robot, you'll want as much, if not more, maneuverability than the offense.
Great robot design. It can obviously be countered by a higher positioned shooter or shooting from the fender, but I think you're gonna get on a lot of teams nerves. Just make sure your drivers get a LOT of practice driving with this robot close to the fender. |
I would recommend making a slot in the back so the human players can feed your hopper so you can clear balls.
To be able to play defense you need to first cross over to the other side of the field... Can this robot do that? |
It's always fun to see robots who take "alternate" game approaches.
One suggestion I would make is to add some sort of a gate at the bottom of your catching hopper so that the balls dont necessarily start firing as soon as one drops in. That way your not collecting a blocked shot only to bury it right back into the other team. Good luck. -Brando |
IMO you have a significant flaw in this design. The blocker should be as far over to the side of robots that you are blocking as possible and sloping down away from that to feed your return mechanism. The way you have it the shooters can gain height across your entire robot before hitting the barrier on your robot. This will allow a large number of robots to shoot right over you.
Good offensive robots will be designed so that the ball leaves the robot's frame/bumper perimeter at a height over 60" so that this strategy won't work against them, but from the posted designs so far this will have some success. Also is it possible that alliances can shoot more than 3 balls in your robot before you clear them? You make an easier target than the baskets. Yes I know this not in the spirit of the rules but technically you can concievably rack up penalties and it will appear to be your fault depending on the referees/circumstances. |
#10
We can crossover the bump, but we need teamwork (or coopertition) to get onto the bridge as we have no way of manipulating it. |
#11
It's an interesting concept, but I'm not sure the dynamics of the game will work out the way you think it will. If I'm on the key and you're in front of me, I'll simply back up and dare you to follow.
#13
Would be curious to see this up against a low/mod scorer and or fender bots. |
