Go to Post Even worse, you could have a "Kiss the Paul" contest. I heard he squeals when you pick him up too. - AndyB [more]
Unread 20-02-2012, 10:20
stintzi stintzi is offline
FRC #3290
stintzi is an unknown quantity at this point
Holding back parts
Alright, I know we can withold up to 30 pounds of fabricated material. Can we also withold our cRIO, camera, range finder, and gyro?
Unread 20-02-2012, 10:28
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Holding back parts
Sure! As long as you haven't made any modifications to them or assembled them with anything else, they won't count towards your 30-lb limit. If you have modified them or assembled them with anything else, then they'll count as a Fabricated Item and against your 30-lb limit.
Note: Soldering PWM wires or connectors to an ultrasonic sensor or gyro will count as modifying it and it will be a Fabricated Item at that point.
