Go to Post "The rio has a boulder sized hole though it? *shrug* Just duct tape it. That doesn't let the code out, right?" - Bkeeneykid [more]
Unread 20-02-2012, 17:42
demons858 demons858 is offline
FRC #0858 (Demons)
demons858 is an unknown quantity at this point
programming compressor code
Hello, our team is having issues programming the compressor. Every time we program the compressor to work, the rest of the program fails to work. We lose control on the motors solonoid and etc. We also get an error referring to the compressor control loop. I am wondering if anyone else has had this problem or if someone can offer help
Thanks
Unread 20-02-2012, 17:44
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: programming compressor code
Be sure to go to Periodic Tasks.vi and enable the compressor control loop there (it is disabled by default).
I'm right 90% of the time, so why worry about the other 3%?
Unread 20-02-2012, 18:15
FRC #0858 (Demons)
We have done that multiple time and ways, still has not worked, the code runs with out the compressed loop vi but then the compressed does not run
Unread 22-02-2012, 10:40
FRC #0858 (Demons)
We have fixed our problem, turns out that if ur cRIO is version 2 and labview is at 4 they compressor code is not ur friend
Unread 22-02-2012, 11:41
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I assume the "version 2" cRIO means the new 4-slot one, but I don't understand what "labview is at 4" means. What did you do to fix it?
