Go to Post Let's not speak without knowing the "facts." If you say something please have valid reasonings behind it. =) - Arefin Bari [more]
Unread 20-02-2012, 18:37
kingpinzs kingpinzs is offline
None #4086
kingpinzs is an unknown quantity at this point
Need help getting spike relays working
Code:
Relay hopper;
hopper(1);
if(joybutton(1));
  hopper.Set(Relay::kOn);
  hopper.Set(Relay::kForward);
It doesnt do anything at all.
How do I get the spike relays working to test?
Unread 20-02-2012, 19:59
DavisC DavisC is offline
FRC #0539 (Titans)
Rookie Year: 2010
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Re: Need help getting spike relays working
Ok, for my code, I don't need the kOn at all.
Is the PWM wire properly plugged into the Relay side of the DSC instead of the PWM side?
Also when the button is pressed, what do the lights next to slot 1 of Relay do?
And do the lights on the Spikes change?
If the answer to the first 2 are yes, and the third no, try messing with the wire more (or a different 1).
SideNote:
WhooHoo, 100 posts!
And congrats on your 1st post!
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 20-02-2012, 20:38
None #4086
1. Yes but both were tried
2. the lights don't even come on
3. the lights don't change
Unread 20-02-2012, 20:48
FRC #0539 (Titans)
Rookie Year: 2010
By any chance are the lights on the Relay side red by even when not enabled?
Also are all 3 green lights on the DSC?
FRC Team 539
Unread 20-02-2012, 23:42
kccowan kccowan is offline
AKA: Ken Cowan
FRC #1073
Rookie Year: 2010
kccowan is an unknown quantity at this point
Originally Posted by kingpinzs View Post
Code:
Relay hopper;
hopper(1);
if(joybutton(1));
Check out Relay.cpp in WPILib. Relay have a direction, kOn sets both forward and reverse. kForward sets only forward. If it was wired correctly, I'm guessing you want to remove the kOn call.
KC
Unread 21-02-2012, 01:32
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Relays won't do anything if the robot is disabled. Did you enable it from the Driver Station when you ran the test?
