Go to Post "I don't need an anniversary party. Use the money for the kids on the robotics team."- Walter Suchowiecki, BMS technician - Wayne C. [more]
Unread 21-02-2012, 01:19
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
Damaged Spike
We have two VEX Pro Spikes that do not respond to the control signals. The wiring looks correct and we are able to detect +4V on the A and B wires at the correct time. The LED glows orange all the time. Both had been plugged into the PWM outputs of the DSC before. The students did not read the DSC documentation and had never used a Spike in previous years. Is it likely that the Spikes are now damaged?
We are not using the ribbon cable for the DB37 connection to the CRio.
Thanks.
Phil
Unread 21-02-2012, 11:24
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Damaged Spike
Make sure the PWM cable is properly seated in the Spike.
With the robot enabled and the Spike set to one direction-to see the change if it occurs (and the motor disconnected for safety if necessary), try removing and reinserting several times in slightly different directions ech time.
Unread 21-02-2012, 19:22
BrandonGlatz BrandonGlatz is offline
Sparky
FRC #2865 (Roboteknix)
Team Role: Electrical
BrandonGlatz is on a distinguished road
Re: Damaged Spike
That is the exact behavior of a dead spike. If moving the wire doesn't help, then it is probably dead.
Unread 21-02-2012, 20:31
arizonafoxx's Avatar
arizonafoxx arizonafoxx is offline
FRC #4395 (T-Rex)
arizonafoxx is an unknown quantity at this point
Re: Damaged Spike
We had the exact same failure this weekend. Orange light on all the time, good fuse, good wiring but no actuation. We changed the spike and nothing else and now it works perfect. I suspect the female pins for the signal cable inside the spike are widened out from all the years of use and could be fixed by pressing them back together, but that would require opening the spike and making modifications which would not be legal. The spike is now in the box of illegal practice parts and if we can fix it will be used as such.
Unread 22-02-2012, 00:33
Mentor
FRC #2587
Rookie Year: 2011
Re: Damaged Spike
It looks like the problem was the PWM cables not being pushed in far enough. I took the Spike to work and tested it using a DC supply. I was able to get it to work with input voltages much lower (1 V) than what the specifications say is required (3 V).
I don't think that the socket for the PWM cables were worn out since these were brand new. This team has also never used Spikes in their robots before.
Thanks for the tips.
Phil
Unread 22-02-2012, 14:02
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
Lightbulb Re: Damaged Spike
Spike should be plugged into relay PWM section of the DSC. check if you have doe that because it is really IMPORTANT!!!
Team 1369
Senior
Head Programmer (Java)
Head Electrician
Unread 22-02-2012, 17:39
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Damaged Spike
[R58-M] Devices may be repaired, provided the performance and specifications of the component after the repair are identical to those before the repair.
New rule this year. You're allowed to repair broken electrical parts back to factory specs. I think it's thanks to the massive amounts of blown FTC motors last year.
I think he already discovered and rectified that part of the problem.
