Go to Post You're here for them, not for you. - Chris is me [more]
Unread 21-02-2012, 12:33
jalmos jalmos is offline
FRC #4166
jalmos is an unknown quantity at this point
Victor problems..... we think?
We are using a motor to raise an arm for our robot. It was working great and now it is not strong enough. Before the victor running to this motor had both 12 volts running to it and out of it. Thus making our motor strong enough.
Now there is 12 volts going to it and only 5.8 volts coming out. (thus making our arm not strong enough. Any suggestions. There had not been any changes on the robot except for an air compressor that runs the pneumatics. Any suggestions?
Could our victor we at fault. Thanks for your help and advice.
jalmos
Unread 21-02-2012, 15:56
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
Re: Victor problems..... we think?
By any chance, do you have the speed controller declared as a Jaguar in your code? that would make it go about half speed.
Check your controls to ensure that you are giving full power to those motors.
Using a voltmeter, ensure that the speed controlled is receiving around 12v.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 21-02-2012, 16:16
nitneylion452's Avatar
nitneylion452 nitneylion452 is offline
AKA: Joe Lee
FRC #3167 (Environmental Tectonics Crusaders)
Rookie Year: 2010
nitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud of
Unhappy Re: Victor problems..... we think?
It could also be possible that someone changed the value passed to the victor to half speed. Look through your code for that.
Also, you could have a every dead or no good battery (a battery that is no good will still charge to normal voltage, but will experience a severe drop in voltage when put under load.) Check the voltage the battery is giving when you operate the arm.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
