Go to Post These teams aren't elitists, but they sure are elite. - [more]
Unread 21-02-2012, 12:43
DFZXA DFZXA is offline
FRC #3055 (Furious George)
Rookie Year: 2007
DFZXA is infamous around these parts
Quadratic equation problem
I took data from a sensor and basically tried to use the quadratic equation on it. When I plug in a number for it it would work, but the problem is that the motor just won't run when I do it. I've attached the program I made for it. If anyone could guide me in the right direction that would be much appreciated.
Unread 21-02-2012, 15:02
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Quadratic equation problem
Where are you putting the code you posted a picture of? What sensor are you reading?
What are you trying to do with this computation?
Unread 21-02-2012, 17:23
Rookie Year: 2007
The code is in the teleop.vi. It's being read from a sonar (after the conversions). I basically needed to run a motor at different speeds based on the distance, but it didn't work well linearly.
Unread 21-02-2012, 17:40
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Let "y" be the output from that code, and "x" be the input.
Then it looks like you are computing
y = -8.24x2 +12.3x -3.97
See attachment. Is that what you intended?
Unread 22-02-2012, 10:53
Rookie Year: 2007
Yes that's exactly how I wanted it, but the motor just sits there and does nothing when I tried that.
Unread 22-02-2012, 11:02
Ether's Avatar
Rookie Year: 1969
Put a probe on the output from your equation (the input to MotorSetOutput) and see what value is there when "the motor just sits there and does nothing".
