what could be wrong with this code. The robot is not responding
/* Copyright (c) FIRST 2008. All Rights Reserved. */ /* Open Source Software - may be modified and shared by FRC teams. The code */ /* must be accompanied by the FIRST BSD license file in the root directory of */ /* the project. */ /*----------------------------------------------------------------------------*/ package edu.wpi.first.wpilibj.templates; import edu.wpi.first.wpilibj.Jaguar; import edu.wpi.first.wpilibj.Joystick; import edu.wpi.first.wpilibj.RobotDrive; import edu.wpi.first.wpilibj.SimpleRobot; /** * The VM is configured to automatically run this class, and to call the * functions corresponding to each mode, as described in the SimpleRobot * documentation. If you change the name of this class or the package after * creating this project, you must also update the manifest file in the resource * directory. */ public class Team4163 extends SimpleRobot { /** * This function is called once each time the robot enters autonomous mode. */ Joystick leftStick; Joystick rightStick; Jaguar arm; Jaguar claw; Jaguar launcher; RobotDrive drive; Jaguar launcherOpposite; boolean constant = true; double LAUNCH_CONSTANT = 0.5; public Team4163 () { leftStick = new Joystick(1); rightStick = new Joystick(2); drive = new RobotDrive(1,2); drive.setInvertedMotor(RobotDrive.MotorType.kFront Left, true); drive.setInvertedMotor(RobotDrive.MotorType.kFront Right, true); drive.setInvertedMotor(RobotDrive.MotorType.kRearL eft, true); drive.setInvertedMotor(RobotDrive.MotorType.kRearR ight, true); arm = new Jaguar (3); claw = new Jaguar(4); launcher = new Jaguar(5); launcherOpposite = new Jaguar (6); } public void autonomous() { } ///This function is called once each time the robot enters operator control. public void operatorControl() { drive.setSafetyEnabled(true); while (isOperatorControl()) { drive.tankDrive(leftStick, rightStick); } drive.setSafetyEnabled(true); drive.tankDrive(leftStick, rightStick); double z = leftStick.getZ(); while(constant = true) { if (z > 0.5) { launcher.set(LAUNCH_CONSTANT * 2); launcherOpposite.set(LAUNCH_CONSTANT * -2); } else { launcher.set(LAUNCH_CONSTANT); launcherOpposite.set(LAUNCH_CONSTANT * -1); } } if (rightStick.getRawButton(3)) arm.set(0.5); else arm.set(0); { if (rightStick.getRawButton(2)) { arm.set(-0.5); } else arm.set(0); } if (rightStick.getRawButton(1)) { claw.set(1); } else claw.set(0); } } } When I build the project in Netbeans nothing is wrong with it, but when it is deployed the robot doesn't respond. everything seems to be wired up correctly. The robot sees that there is code in it based on the driverstation but the robot doesn't do any of the controls Last edited by DPG2013 : 21-02-2012 at 13:47. Reason: Forgot something |
Re: what could be wrong with this code. The robot is not responding
Two comments. My best guess is that you need a sleep() or wait() or whatever the java equivalent is in the body of your while(isOperatorControl()) loop. If the brackets in your post match your robot code, then your launcher code will probably never get run, or will only get run before you disable the robot.
Code:
while (isOperatorControl()) <-- as long as you're in operator control, your robot will be in this loop. It should be responsive to your joysticks though. You may want to put a wait(0.001) call in (or whatever the java equivalent is) because this thread may be monopolizing the cRio CPU
drive.tankDrive(leftStick, rightStick); <-- this will only get called once, since you're not in a loop at the time you call it.
while(constant = true) <-- if this is java or c++, you need to do constant == true. As this stands, you're assigning true to constant, and then testing if it is true, which means this loop will never end
if (z > 0.5)
else
else
arm.set(0);
arm.set(-0.5);
else
arm.set(0);
claw.set(1);
else
claw.set(0);
wow..... You seriously need to start tabbing your code and keeping track of all your brackets. Also you use while loops inapropriatly. this loop:
Code:
if (z > 0.5)
else
Code:
Once you clean up the loop issues noted above, you should check why you are inverting 4 motors on a robotDrive instantiated with 2. Typically you would only use kLeft and kRight (or instantiate with 4 controllers) and only invert one
