Bridge problems!
Hello all robotics teams! Our team, 4286, is having some problems with the bridge. We are working in a school with I believe 802.11g network, at 2.5ghz. The problem is when you try to connect, it switches between connection and no connection. I have reason to believe this is because of such interference. When I reset it and set it to 5 ghz, it still didn't work, my comptuer couldn't pick it up. My question is should I continue to work on it all night tonight or just wait until we get a new one? (We already have it shipped to us, its jsut not here yet). I am the programming capt if anyone was wondering.
Thanks -Ex ![]() |
Re: Bridge problems!
Use a program like InSSIDer to scan for wireless networks and show which channels are least likely to interfere with your robot's D-Link router. Log in to the router and configure its wireless settings manually to be on the desired channel instead of letting it select a channel on its own. That usually helps.
This may be an obvious question, but does your computer support 5 GHz?
We had a "scrimmage" event in St Louis on Saturday and with about 20 teams there we were getting very bad wireless interference issues. We have a (I believe) 1 year old laptop that we use for our driver station and it does not support 5 GHz. We tried changing the DLink's channel selection from auto to manual but still had the same issue. By the way, every team had this issue. If you are experiencing a similiar problem your options are to either somehow get the other wireless networks turned off where you are or find a computer that supports 5 GHz, or just run a long ethernet tether cord. |
In case you didn't see it, the team update from 2012-01-20 states:
