Go to Post "You have not lived until you have done something for someone who can never repay you." - unknown - rufu5 [more]
Unread 21-02-2012, 14:06
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
Rookie Year: 2011
tilky is an unknown quantity at this point
how to stop a compessor when disabled
how would you stop the compressor when teleop is disabled. I tried putting a compressor stop under disable, but it doesn't restart.
Unread 21-02-2012, 14:08
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: how to stop a compessor when disabled
All of your outputs will be disabled automatically when the robot is disabled, no need to add any code to disable the compressor.
Unread 21-02-2012, 14:20
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
Rookie Year: 2011
but it doesn't. do you think it is electrical and not programming?
Unread 21-02-2012, 14:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It could be wired wrong. How does the compressor get power?
Unread 21-02-2012, 15:40
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Is the pressure switch wired in series with the compressor? It needs to be fed through the DSC to a Spike. The Spike is disabled by the Crio when the rest of the robot is disabled.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 21-02-2012, 16:34
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by Vikesrock View Post
A bad DSC is the only thing I have seen that can cause relays to keep running when the robot is in Disabled mode.
Connecting a Spike's control input to a general purpose digital output instead of the proper relay pins can do it too.
