Go to Post Please drill responsibly! - IKE [more]
Unread 21-02-2012, 17:12
APrettyDucky's Avatar
APrettyDucky APrettyDucky is offline
AKA: Egor001, Minecrafter Supreme
FRC #3828 (12 Pretty Duckies)
Rookie Year: 2011
APrettyDucky is an unknown quantity at this point
Adding a delay to commands
What I need to do is figure out how to add a delay to a command, like when i press and hold button, the motor that is supposed to turn is delayed for a second, and then turns. I am also wondering how to implement this into autonomous.
Thanks
Unread 21-02-2012, 17:27
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Adding a delay to commands
Thanks
You have two choices:
1) state machine
2) periodic tasks
Unread 23-02-2012, 21:48
kentwedeking's Avatar
kentwedeking kentwedeking is offline
LabVIEW Zealot
FRC #0967
kentwedeking is on a distinguished road
Set a flag that you've pressed a button via a functional global or using a global variable and put your sequence code in the Periodic Tasks VI. If you leave it in your Teleop or autonomous you'll not be happy ... it'll block your execution and cause you code to have delays you don't want ...
