Go to Post There has to be a point where you go "I do not agree, but I can understand why they did it." - Lil' Lavery [more]
Unread 21-02-2012, 22:50
rickyman20 rickyman20 is offline
FRC #3933
Rookie Year: 2011
rickyman20 is an unknown quantity at this point
cRIO connection error
I am connecting from a mac with a windows partition. I enter this partition and I am able to connect to the modem, but not the cRIO. I am still able see the camera for some reason. Could anyone help me?
Unread 21-02-2012, 22:53
MAldridge's Avatar
MAldridge MAldridge is offline
Lead Programmer
AKA: Rube #1
FRC #0418 (LASA Robotics)
Rookie Year: 2010
MAldridge will become famous soon enoughMAldridge will become famous soon enough
Re: cRIO connection error
assuming by modem you meant radio, then you may want to check the cables you are using between the radio and the cRIO. additionally, make sure the cRIO IP is set to 10.te.am.2 in your robot project.
For example, I am on 418, so my cRIO is at 10.4.18.2 .
good luck
'Why are you a programer?' --Team Captain
'Because the robot isn't complicated enough!' --Me
Unread 21-02-2012, 23:00
FRC #3933
Rookie Year: 2011
Another computer works with the robot.
Unread 21-02-2012, 23:07
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
Rookie Year: 2011
theawesome1730 will become famous soon enough
Is the Macs IP address correct? It should be 10.te.am.9
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 23-02-2012, 07:49
FRC #3933
Rookie Year: 2011
Yes, I have checked every thing about the IP but I still have the same problem
Unread 23-02-2012, 10:35
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
Have you tried connecting your computer straight to the cRIO with a crossover cable? Can you ping the cRIO from the computer?
Good luck,
Oliver
Last edited by linuxboy : 23-02-2012 at 10:44. Reason: Read previous posts more closely
