Go to Post ...there is just something that I like about the smell of fresh engine oil... - Matt Attallah [more]
Unread 23-02-2012, 22:21
ChristopherSD's Avatar
ChristopherSD ChristopherSD is offline
FRC #0201 (FEDS 201)
Team Role: Driver
Rookie Year: 2010
ChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud of
Re: 1918 NC GEARS 2012 Robot
Originally Posted by flippy147852 View Post
That is correct, unfortunately. We didn't want back to back events, so we switched to Gull Lake instead. Will you guys be at Troy?
Nah--Traverse and Wayne (back to back). I'm also not a fan of two consecutive competitions.
In regards to Troy, I'll probably come watch like I always do. It's a tough competition.
Unread 23-02-2012, 22:48
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
It is about 36" tall. (edit: already been answered)
The primary roller in the frame and the arm roller in the arm are both powered by the same FP motor. The roller motor/sprocket axis is in line with the arm pivot, so the urethane belt tension doesn't change with arm position. The arm roller does a decent job picking balls out of corners, etc., when the chassis isn't moving too fast, but for open field pickup we generally keep the arm up.
Our alignment is simple, but seems to work well. Mostly its just the drivers eyeballing it. We also use the camera when needed. We don't expect to win any Rockwell Automation Awards.
We have seen the same distance spread due to ball variation that most others have reported, and have taken steps to minimize its magnitude and impact. We did some studies and found that the "sweet spot" for scoring for a given wheel speed combination was quite deep. (We run the bottom wheel wide open and throttle the top wheel to control distance, which improves backspin). Shooting straight on, we could hit about 5/6 from within a distance tolerance of +/- 1 foot from the "ideal" distance thanks to backspin and the backboard. It dropped off to about 1/2 at 2 feet from "ideal". Once we figured this out, we changed our approach. We quit worrying about adjusting wheel speed as a direct function of distance and set up a few standard speeds for shots we expect to be taking often (short, medium, and long, etc.). Now, we just concentrate on the aim (azimuth) and get in the ballpark for distance, something the drivers can judge at a distance or quickly see from the camera. With a bit of practice, they were able to line up and shoot in a couple of seconds. We expect to miss a few, but that is likely to happen anyway because of ball variation. We'll just pick 'em up and shoot again.
We learned a lot about shooters this year (starting from nothing, it didn't take much!). The main thing we learned (thanks to some help from my brother) is that the motor doesn't really power the ball to the target. The kinetic energy in the ball comes from the stored energy in the spinning wheel (flywheel). A bigger motor (or more of them) doesn't throw the ball farther, it just improves the recovery time between shots. What you need is a good flywheel(s) with some decent grip (texture and compression) on the ball. We went from two 775's per wheel to one, and redesigned our wheels.
We chose early on to concentrate on shooting from the key and closer. Not only is the scoring percentage better from up close, but it lets us gear the shooter wheels for faster recovery between shots and keeps us in or near the protected zone. We also made ball collection and ball handling reliability a priority. Collecting from one side and shooting from the other allows for a straight ball flow. We also wanted a very low CG. This approach works well for that.
We saved a few new balls to recalibrate the wheel speeds prior to competition. The new ones go a lot farther than the well used ones.
Special thanks to whoever it was that came up with the trajectory calculator. It was a priceless tool in our design process. We used it to determine ball speed and launch angle, which drove amost every other detail of the ball feeder/shooter.
Edit: I hope the GDC offers their wisdom on the <R35> obscured number issue. This will come up again and again this year and in the future. IMHO, the intent of the rule is met if you can read the numbers while in the starting configuration. People don't come to events to check out the sleek lettering on the bumpers. They come to watch what the robots can do. It would be a bummer if this became a significant design constraint for manipulators. IMHO, putting numbers on the arm wouldn't satisfy a lawyer, either. Numbers get obscured in the course of playing the game by other robots, field elements, etc. I'm neither a lawyer or a GDC member, so I'll deal with whatever happens.
We will miss TC. We have many fond memories and hope to return soon. It just didn't work with our schedule this year.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Last edited by Wayne TenBrink : 23-02-2012 at 23:01. Reason: Spent so much time drafting, it was obsolete!
Unread 23-02-2012, 22:53
Which calculator? (link?)
Thanks
Unread 23-02-2012, 23:04
Thanks
I'll post a link when I find it. One of our students found it.
I believe this is the one - from 2151 "Monty Pythons". Thanks to the "engunneer"
http://engunneer.com/content/blog/fi...ry-spreadsheet
FTC 6043 & 7911
Unread 23-02-2012, 23:47
P.J.'s Avatar
P.J. P.J. is offline
Proud Member of the Herd
Rookie Year: 2007
P.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond repute
I totally agree, that's exactly the way I read the rule. Also, the justification being they want announcers and stuff to be able to see it, so I figure it doesn't need to be visible on all sides all the time. I just wanted to point out what people's concerns might be so you guys are aware. I would hate to see you get attacked because of some stupid little rule.
P.J. Lewalski
Team 910-The Foley Freeze -- Student 2007-2010, Mentor 2012-2016
FRC Referee 2011-Present
Referee at 29 Regular Season Events, 3 World Championships, 24 Off Season Events, and Counting
Unread 22-02-2012, 14:16
flippy147852's Avatar
flippy147852 flippy147852 is offline
respect the hat
AKA: Felipe Agurto
FRC #1918 (NC GEARS)
flippy147852 is an unknown quantity at this point
Originally Posted by JABot67 View Post
How were you lining up to shoot? My team was under the impression that a robot would need some sort of vision targeting or driver station camera feed (for manual targeting) in order to shoot accurately. But it doesn't look like you have a camera...
We do have a camera, it's just tucked away inside the robot and looks up at an angle. We don't want our drivers flying blind, you know
NC GEARS = Newaygo County Geeks Engineering Awesome Robotics Solutions
2009: 5 Events, 60-25-2. 1 District Win, 3 Finalists
2010: 4 Events, 51-13-6. 1 District Win, 1 Regional Win, 1 Finalist
2011: 4 Events, 58-18-4. 2 District Wins
2012: 4 Events, 46-25-0. 1 District Win, 1 Finalist
Total: 17 Events, 215-81-12. 308 matches in 4 years
Scouting it all: Priceless
Unread 22-02-2012, 15:07
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
I really love the centering ability of the intake arm. Really well executed.
Unread 22-02-2012, 17:28
techvikesmom techvikesmom is offline
FRC #2054
techvikesmom is an unknown quantity at this point
Great Robot! Got to see your bot in action last weekend at Code Red Practice Field. Fast, great scorer and great feeder bot and many more great concepts!! And thanks to Team #2771 Code Red for your hospitality again this year!! Good luck in districts to both and we will see at West Michigan districts.
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Agreed, very cool. What did you use to spiral the intake roller?
Unread 22-02-2012, 17:54
I am watching this video over and over. Still highly impressed so far for reasons I can't quite put my finger on. I think you guys have really done it this time. So far, the best bot I have seen.
Unread 22-02-2012, 19:52
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Team Role: Leadership
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
Looks awesome guys. Really impressive.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 22-02-2012, 20:22
respect the hat
AKA: Felipe Agurto
We spiraled a V-belt around some PVC and then screwed it in to make the threads on our roller
Unread 23-02-2012, 22:25
P.J.'s Avatar
Rookie Year: 2007
So on YouTube I noticed some comments regarding Rule R35, which states:
Teams shall display their team number on the Bumpers in four locations at approximately 90° intervals around the perimeter of the Robot. The numerals must be at least 4 in. high, at least ¾ in. in stroke width, and be either white in color or outlined in white. Team numbers must be clearly visible from a distance of not less than 100 ft, so that judges, referees, and announcers can easily identify competing Robots.
The problem being your arm covers the numbers on the front. However, this doesn't say they all have to be visible at all times, so I think its a non issue, but I wanted to make sure to point this out. A simple fix would be to put your team number on the arm. I believe that would be sufficient to block any complaints.
And I am floored by this robot. You guys do it every year and it makes me glad to compete in Michigan so I can see what you guys do. See you at West Michigan and Troy, I'll have to come and snoop around a little bit and cry at the beauty of your robot.
P.J. Lewalski
