Go to Post A better way would be better..... - WizardOfAz [more]
Unread 02-22-2012, 01:47 PM
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
Robots can't count: Microswitches
We are using a microswitch on our robot to add and subtract the balls. The MicroswitchesWe are plugged with GND on C and SIG on NO (normally open).
I will add the code when I get the chance but it is basically:
Code:
Int totalBalls = 2
public int microSwitch(int totalBalls)
If (addball.get() = true and totalBalls >= 0 and < 3
Then totalBalls += 1
If (minusball.get() = true and totalBalls > 0 and <= 3
Then totalBalls -= 1
Else if totalBalls > 3 || totalBalls < 0
Then totalBalls
return totalBalls
When I hit the switch, it calculates the addition or subtraction, but when the switch is released, it goes back to the original value. Why an't a robot count?
Team 1369
Senior
Head Programmer (Java)
Head Electrician
