Go to Post How well does peanut butter transmit heat? - Lil' Lavery [more]
Unread 02-22-2012, 02:09 PM
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
Unhappy Driver Statn and Inputs
I am trying to have the driver station read relay movement, Microswitches, and
PWMs
I tried getDigitalIn() for the Microswitches, but having the driver station class on getInstance, when I switch to teleopPeriodic, it says RobotDrive not updated enough on a 5 ms delay. The teleop worked after moving it. DriverstationLCD works, but not the driver station class.
Any suggestions?
Team 1369
Senior
Head Programmer (Java)
Head Electrician
Unread 02-24-2012, 07:04 PM
Slix Slix is offline
AKA: Peter Kowalczyk
FRC #2115 (NightMares)
Rookie Year: 2010
Slix is an unknown quantity at this point
Re: Driver Statn and Inputs
It seems like your code that was sending to the driver station was delaying your iterative loop for some reason. Was teleop completely broken? Also, was it RobotDrive that was giving you the delay message? I'd expect PeriodicRobot to do that.
It could be that DriverStation.getInstance() or DriverStation.getDigitalIn() is taking too long to return.
Can you post the part of the code that has the issue?
Also, you may want to look into SmartDashboard.
Unread 02-24-2012, 07:21 PM
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Rookie Year: 2010
slijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to behold
You should be using the setDigitalOut() method to do that, not getDigitalIn(); that method returns the state of a digital input on the Driver Station, not the DSC.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
