Go to Post In 2001 instead of staring at the field at the game I turned around and watched the people watch the field. All I could see was a mass of people from all corners of the world, eyes lit up, gears turning in their heads. That, to me, is FIRST in action. - Jessica Boucher [more]
Unread 23-02-2012, 10:46
FTCTeam3787 FTCTeam3787 is offline
FTC #3787
FTCTeam3787 is an unknown quantity at this point
[FTC]: Servo has parkinsons???
Has anyone else had issues with the 180 servos twitching out? We have 2 on our bot, 1 twitches for 5-10 seconds every time we drive the bot, bu the other does not. We have swapped out the twitchy servo and still have the same prob.
thanks
- Team #3787 "The Green Exploding Volcano Monsters"
Unread 23-02-2012, 15:41
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Re: [FTC]: Servo has parkinsons???
We've had the same problem, might be an issue with the mechanism its attached to causing constructive harmonic interference (in other words, the servo corrects its position at the same frequency the mechanism sways/bounces/oscillates). If this is the case, mechanical dampers (such as a plate in contact with the mechanism to slow it down due to friction) might help.
Unread 23-02-2012, 20:35
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
I was told it is an electrical problem, between your motor/servo control boxes.
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 23-02-2012, 21:02
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Rookie Year: 2010
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
This right here is generally the correct answer. The servos that you guys use in FTC are similar to that found on RC cars and planes. I have observed in both of these the "twitching" that you described. Every time I have been able to correct this simply by putting rubber washers in the mechanism and tightening it until the jitters stop. Any other form of stabilizing mechanism works too.
Before you do this, I will warn you that any kind of drag on the mechanism will cause inefficiencies. If you need the speed or the full strength of your servo to do the job, don't do this. Also, putting too much drag on the mechanism could cause the servo to overheat.
My recommendation: If the jitters in the servo don't affect anything, ignore them. There's likely nothing wrong with the servo and messing with an already working mechanism can screw things up.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 24-02-2012, 06:47
ssi ssi is offline
AKA: David Spangler
FTC #2843 (Under the Son)
ssi will become famous soon enough
We have also had this problem before. In most (if not all) cases it can be traced back to a DC motor. Our guess is the brushes on the motor start wearing (or possibly a short in one of the windings) and causing electrical noise. Once the offending motor has been replaced, the problem goes away.
Unread 24-02-2012, 07:43
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Two possible issues here...
1. The servo is not firmly mounted in place. As the servo moves in it's mount, it may over shoot it's target.
2. If the servo wiring is running close to motor wiring, the noise generated in the motors may be picked up by the servo wiring and interpreted as a command. Try pulling the motor wires and then operate the servo to check if it jitters.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 24-02-2012, 11:09
FTC #3787
Excellent suggestions everyone. We'll try in this order and let you all know what works...
1. Check servo mounting to make sure its secure.
2. Move servo wires away from DC motor wires - Right now they are all bound together with zip ties.
3. Check all DC motors to make sure they are working correctly (as much as we can).
4. Ignore it.
- Team 3787
Unread 28-02-2012, 11:58
hokieteach hokieteach is offline
FTC #5465
hokieteach is an unknown quantity at this point
We are having a very similar issue. Ours will work fine while running a prototype test in labview, but when we deploy our code to the brick and attempt a teleop our servos jitter and then go nuts for a few secs and then become non-operational. Has anyone ever experienced anything like this?
Unread 28-02-2012, 12:10
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
There is a known Servo problem with the LabVIEW code that was included in the latest main update. Here is an earlier post I made regarding the patch.
http://www.chiefdelphi.com/forums/sh...74&postcount=5
Phil
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
