Go to Post "If everything is possible, there is the possibility that something is impossible..." ::sigh:: :) - Kims Robot [more]
Unread 23-02-2012, 14:04
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
Rookie Year: 2010
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
Help me understand PIDController::OnTarget()
Code:
bool PIDController::OnTarget()
	bool temp;
	CRITICAL_REGION(m_semaphore)
		temp = fabs(m_error) < (m_tolerance / 100 *
			(m_maximumInput - m_minimumInput));
	END_REGION;
	return temp;
I'm having trouble understanding the implementation of this function. In the context that I was using it my max input was 100 and my minimum input was 0. I was using the default tolerance of 0.05 (assuming this means 5%).
0.05 / 100 *100 = 0.05.
This means my error would have to less than 0.05 to be OnTarget regardless of setpoint.
For a setpoint of 10 I would have to be within 0.05 which is 0.5%, not 5%.
For a setpoint of 100 I still have to be within 0.05 which is 0.05% of 100, not 5%.
Shouldn't the implementation be the percent error formula?
% error = (|Your Result - Accepted Value| / Accepted Value) x 100
Something like:
Code:
	bool temp;
		temp = fabs(m_error)/m_setpoint < m_tolerance;
	END_REGION;
	return temp;
Unread 23-02-2012, 14:17
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
Rookie Year: 2011
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
Re: Help me understand PIDController::OnTarget()
If you want a tolerance of 5%, you should use a tolerance of 5.0, not 0.05. I made the same mistake.
Unread 23-02-2012, 14:21
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
The implementation looks correct to me. It looks for the error to be less than the tolerance % of the full range. Since m_tolerance is divided by 100, I assume that 5% should be 5.0, not 0.05.
HTH
Fast, cheap or working - pick any two!
Unread 23-02-2012, 14:40
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
Rookie Year: 2012
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Lightbulb Re: Help me understand PIDController::OnTarget()
I'm having a little trouble figuring out where your confused, so I'm going to make two seperate explanations:
a)
To get a tolerence of 5% (as in you example setpoint +- 5.0) you would pass in a tolerence of 5.0; the math converts the percentage as a value from 0 to 100 to a value of 1.00 to 0.00, and uses that for the computation.
The percentage is literally a percentage value, 100 = 100%, 1.0 = 1%. It's exactly the opposite of what I expected it would be (especially in an engineering setting like this); also, to make matters worse, theres an extra unnecessary floating point division to taking place in the OnTarget function (this division should take place in the set tolerence function instead, but oh well)...
b)
The reason OnTarget uses the Min/Max input is fairly good actually (I actually thought at first it worked the other way, and it added a lot of complexity to this scenario)
If you consider a turret, which autotargets the hoop and uses a gyro to determine it's rotation, you will frequently changing the setpoint to the angle you need to turn; however you need to be within 1deg of the hoop...
If the tolerence were based on the setpoint, a 10% tolerence and a setpoint of 10deg, your target would be 10deg +-1deg, for a setpoint of 20deg, your tolerence would be 20deg+-2deg.
So, in that scenario, if you wanted a 1 deg error, you would have to compute the % error based on the setpoint you chose each time it changed.
Conclusion:
The whole thing would be much simpler (and function the same) if tolerence simply took in a float for the acceptable error value rather than percentage. (ex SetTolerence(1.0); //Tolerence of 1 degree).
Also, a word of caution...
On target will return true if (m_error == 0), so you have to be sure the calculate function has run at least once after each enable before you make any action based on OnTarget().
Unread 23-02-2012, 14:52
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
I think depending on your application, you could make an argument for either method.
For example, if you're controlling the angle of an arm, you probably want the same tolerance range throughout the motion of the arm (as implemented). If you're controlling the speed of a shooter, you'd want to use the percent error formula, so that you have a tighter tolerance as the speed of the wheel gets smaller.
In Java, here's the java-doc for setTolerance.
Code:
     * Set the percentage error which is considered tolerable for use with
     * OnTarget. (Input of 15.0 = 15 percent)
     * @param percent error which is tolerable
Unread 23-02-2012, 15:40
Rookie Year: 2010
At least I undestand the intent now. I think Joe Ross gave the best answer. It makes sense in the turret application. I was using it for my shooter speed where I think percent error makes more sense.
I think percent error is more natural to me because whenever we discussed the steady state error requirements of a control loop in school we always talked about it as a percentage error of the setpoint. i.e. steady state error of +/- 2% might be a requirement. Of course I think we were always talking about controlling speed and not controlling position.
I think I will add my own OnTarget implementation to the WPILib and recompile it. Something like this:
Code:
bool PIDController::OnTarget(bool percent_error)
	bool temp;
    if(percent_error)
    else
END_REGION;
return temp;
Originally Posted by DjScribbles View Post
Conclusion:
I also agree with this.
Originally Posted by Ether View Post
On a side note:
It looks like m_tolerance, m_maximumInput, and m_minimumInput are all constants.
I think the reason they are part of the critical region is that they are accessed in the calculation of the output of the controller and can also be modified at any time by the application threads via methods such as this one.
Code:
void PIDController::SetInputRange(float minimumInput, float maximumInput)
		m_minimumInput = minimumInput;
		m_maximumInput = maximumInput;
	END_REGION;
	SetSetpoint(m_setpoint);
Unread 23-02-2012, 15:44
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Code:
	END_REGION;
Fair enough. They're not constants.
The purist in me would grab copies of the variables in the critical region and move the calculation outside the critical region, but it would hardly make any difference in this case.
Unread 23-02-2012, 16:35
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Just override the class (or copy it) - we can't recompile the lib and even if we could the FIRST infrastructure checks the MD5 checksum.
True but these class members are native machine word-sized thus changing them is an atomic operation in this context. It may not be desirable but it won't screw up.
HTH
Unread 23-02-2012, 17:24
Rookie Year: 1997
I've never heard that before. Where did you hear it? I would have thought that Joe Hershberger would have mentioned the MD5 check instead of helping with instructions on how to rebuild the library in the following thread. http://www.chiefdelphi.com/forums/sh...ad.php?t=89131
I do agree it's better to override a method if possible.
Unread 23-02-2012, 18:40
Rookie Year: 2010
Doesn't sound right to me either. I don't think there exists any requirement that we have to use WPILib at all when programming in C++. It is there for convenience.
Makes sense, I was on that thread and that is where I learned to do the recompile.
The method is virtual so this is an option.
Unread 23-02-2012, 22:38
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
My apologies - I could swear I tried this the first year we had the cRIOs and you got a library version error. When I asked about it, the WPI folks said you had to have special permissions (and be on the "build team") to access the svn repository and do a proper build. Obviously that is no longer the case (if it ever was). Sorry to steer anybody wrong!
Unread 23-02-2012, 18:53
Rookie Year: 2010
I think you're correct that there is no danger of segmentation faults. However, if access to the variables is not synchronized then the potential for logic errors exist.
Example, in the following code the first if-statement could execute with the values of min/max input set to one set of values. The thread executing this code could then be preempted (depending on the thread priority and scheduling algorithm being used) by the application thread and the values of min/max input changed. The original thread would then continue executing the code with new values of min/max input causing undesireable results.
Code:
if (fabs(m_error) > (m_maximumInput - m_minimumInput) / 2)
        if (m_error > 0)
            m_error = m_error - m_maximumInput + m_minimumInput;
       else
           m_error = m_error + m_maximumInput - m_minimumInput;
Unread 23-02-2012, 18:58
Rookie Year: 2010
Can someone explain the difference between these two uses of the semaphore? I see both being used in the PIDController class.
Code:
END_REGION;
Code:
    Synchronized sync(m_semaphore);
Unread 23-02-2012, 22:48
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Code:
END_REGION;
Code:
the first is a semaphore used for mutual exclusion (to protect the critical region), in this use-case the semaphore is taken before and given after a critical region of code and always in the same context - the semaphore includes the concept of ownership (by the thread/task) and recursion
the second is a semaphore used for synchronization, in this use-case the semaphore is taken in one context/thread/task and given or flushed in another context - for example given/flushed in a periodic timer callback function (or maybe an interrupt service routine) and taken in a task/thread
hth
  #15   Spotlight this post!
Unread 24-02-2012, 11:05
Rookie Year: 2010
I figured. So in QNX parlance (which I am most familar with) these would be a Mutex and Condition Variable. However, I don't see where the semaphore is being flushed in the PIDController implementation. The periodic loop is accomplished with a Notifier calling the Calculate() method periodically. Is the sync actually being used somehow here?
