Thread Tools |
Rating:
Display Modes |
Robot Cart
Between the transition period between bag and tag, and competition my team wants to build an all around cart design with wheels such as pneumatic. I have been tossing some ideas around but I can't seem to get any good ones. If possible does anyone have any ideas or CAD drawings for me to bounce ideas off of?
Re: Robot Cart
As a general tip, you should have some sort of platform that lifts the robot up for easy accessibility. Our team uses a special scissor-lift that brings the robot to a comfortable height, and we have crossbars that "jack up" the bot so we could test the drivetrain and put our hands underneath. Think about reusing the cart for years to come as well. Robot shapes and designs change, so make your cart adjustable and give it the ability to hold bumpers and other large items. Most importantly, your cart should be maneuverable and compact enough to fit through tight spaces (use swiveling casters, etc for wheels). We found this out the hard way when our original cart was too wide and too tall to fit through the doorway! Be creative, but be sure to follow the cart rules too (sadly, no music allowed on the cart).
Re: Robot Cart
My advice is to keep it simple. The two most important things it should do are:
Keep it small enough to fit in the pits and allow people to work around it. Locking wheels are helpful (but make sure all students know how to lock and unlock them). Swiveling wheels on one end and straight wheels on the other work best. And a handle at waist height for easy steering and pushing or pulling. Ropes are not so good, but better than nothing if you have a low-to-the-floor cart. I've seen some teams with scissor lifts or pneumatic jacks. Sometimes I'm jealous, sometimes I'm glad we have a simple, solid, flat, dependable, safe surface. Shelves and drawers are nice for carrying the operator console, bumpers or covers, some tools, spare battery, etc. If you're using pneumatics and an offboard compressor, the cart is a good place to keep them (with a battery for the compreesor). Even if your compressor is onboard, you're allowed to pre-charge your tanks. No matter what, it should be a fun project to work on, now that the pressure of build season if off. |
Re: Robot Cart
Don't forget space enough for a camping chair or folding chair of some sort as well as room for your bumpers, both sets.
Also include some basic power system, aka power strips properly rated, for your laptop, chargers for batteries and etc. The last thing I'd add would be a cooler with water or something similar. I know some regionals are tight on food and water brought in but when the heats on, gotta keep cool. |
Re: Robot Cart
Our team's cart is simple, just a folding cart fitting with a solid base of wood and some nice handles. If there was an improvement I would make on it, it would be a place to hold the driver's station. Our driver often has trouble carrying our station (which is very fancy custom acrylic and aluminum) through the crowded pits. If you can get both of those in inexpensively, I'd say it's mission accomplished.
Re: Robot Cart
Re: Robot Cart
http://img1.classistatic.com/cps/po/...828d0n_27.jpeg except it has longer handles, and an attached wooden base of FIRST robot dimensions. You can slide it back and forth between a dolly and a cart for the robot. The handles are just long enough the prop the driver's station on if necessary to wheel it around, but like I said- we haven't really fixed that problem yet. hope that helps. |
Re: Robot Cart
Pneumatic tires might seem like a good idea until you get to a competition and have a flat. Some of those small ones are difficult to inflate, and if you get a real leak in one, they don't roll too well. I'd stick with something that doesn't need to be inflated.
Dr. Bob Chairman's Award is not about building the robot. Every team builds a robot. |
Re: Robot Cart
Remember your cart needs to fit through a standard 36" doorway.
#10
Re: Robot Cart
You could look into getting an AndyMark cart and customizing it.
#11
Re: Robot Cart
We have an aluminum platform cart with a removable handle.
Attached to the deck are two 8020 cross bars. On top of those are two longerons. On the longerons are posts that support the robot. By adjusting the locations of the longerons and posts, we can fit the cart to each year's robot. The height of the posts are set so the robot just clears a standard doorway. If necessary, the posts can be trimmed or swapped out to increase or decrease the robot height. As shown in the pic, the crossbars and longerons also make a convenient place to stick stuff when working on the robot. The cart design is evolving. Last year the height was great for standing and working on the robot, but we couldn't go through doors. This year, we dropped the post height to fit through doors, and the robot ends up at the perfect height to work on while sitting in a chair. Next step is to add stowage for the operator console, tools, and water for competitions. We had stowage for bumpers last year, but may leave them off the cart this time. |
#12
Re: Robot Cart
We have this cart: http://www.harborfreight.com/500-lb-...ble-94822.html
It is ~$150 and is easy to raise the height ![]() |
#13
Re: Robot Cart
