Go to Post In the end, we were successful, but the tale is one of such stupidity that it should be engraved in drool upon a failed math test. - AmLameBro [more]
Unread 23-02-2012, 21:32
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Dashboard source
I am not familiar with LabView but I need to look into adding image overlay support to the dashboard. Can somebody tell me where I can find the source code for Dashboard. My understanding is that it is written in Labview and should be included as part of the "sample code". I installed LabView last night and can't find any sample code about Dashboard. Is it similar to C++ where you don't get the sample code until you install the Workbench update? In other words, is there a LabView update that I need to install in order to get the Dashboard code?
Thanks.
Unread 23-02-2012, 21:37
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Dashboard source
It's on the Getting Started window. The first window that comes up when you start LabVIEW.
Under New you'll see FRC Dashboard Project
You must have installed the FRC LabVIEW (from the KOP stick)
and the LabVIEW Update
Optionally, other pieces like Utilities. Check the bottom of the control system page.
