Go to Post I would feel more comfortable if you used rock-paper-scissor-lizard-Spock. - IndySam [more]
Unread 24-02-2012, 14:03
qpang qpang is offline
qpang is an unknown quantity at this point
program compressor in labview
We are working on our compressor and program it in labview.
We put the
Compsr Open, CompsrRefNum Registry Set and Compsr Start in Begin.vi.
In periodic.vi, removed the disabled structure.
In finish.vi, add CompsrRefNum Registry Set, Compsr Stop and Compsr Close.
I'm not sure do we need to use "Compsr Enabled" module as in labview examples for compressor? If yes, where should we use it?
ID:	12090  Click image for larger version
Unread 24-02-2012, 14:08
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: program compressor in labview
The Enable isn't necessary.
Did you update the name for the Compressor used in Periodic Tasks?
Unread 24-02-2012, 14:52
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
Team Role: Teacher
Rookie Year: 2011
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
You don't need Enable unless you are trying to bypass the spike relay.
As a word of warning there have been many teams, including my own, who have had issues with the default ControlLoop VI not working. In the driver station it returns an error of invalid relay index. If you are not working with an unbagged robot you might have trouble shoot this issue at the competition.
Bookmark these two links to help you later.
http://www.chiefdelphi.com/forums/sh...ompressor+loop
and the one we needed to right custom code:
http://www.chiefdelphi.com/forums/sh...6&postcount=12
