Go to Post You play your best, the refs do their best, and at the end of the day we are FIRST, collectively. - KenWittlief [more]
Unread 24-02-2012, 21:47
JackS's Avatar
JackS JackS is offline
Sideline Observer
no team (EWCP)
JackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond repute
pic: Team 2791 Complete
Unread 24-02-2012, 21:49
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
Rookie Year: 2007
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Re: pic: Team 2791 Complete
Great looking robot (especially next to our wooden collector)! Didn't have much time to see you guys play; too busy figuring our stuff out. One thing I noticed was that your robot has what appears to be six air tanks on your robot. You guys planning on crossing the dridge that often?
Unread 24-02-2012, 22:25
JackS's Avatar
Sideline Observer
no team (EWCP)
Actually, because the elevator is on the same motor as the intake, we needed a way to run the intake without moving balls towards the shooter. To solve this problem, there is a lexan "backboard" that is attached to a piston. The piston changes the compression against the ball enough such that, when the "backboard" is in the back position, we can run the elevator and the balls just spin in place. Once we engage the backboard, the balls have enough compression to move towards the shooter. Thus, in short, we require movement of a piston each time we wish to shoot a load of balls as well.
We did find, through experimentation at the field, that we had enough air to last us approximately 7 minutes of full game simulation. One of the upgrades we plan to make for BAE is to remove the cluster of tanks and replace them with a few plastic ones.
[2009-2014] FRC Team 2791 - Shaker Robotics
Colgate University
'16
Unread 24-02-2012, 23:38
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I can't seem to find any wood or PVC on that robot. Weird...
I hope you guys rock it this year. Best of luck. Me likey.
Unread 24-02-2012, 23:41
Jack and 2791 stepped up an insane amount this year.
And part of the lack of wood and PVC is due to the EWCP harassing Jack about 2011
Unread 24-02-2012, 23:50
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
Very nice robot 2791! Jack, what is the range difference when the shooter hood is retracted and fully extended?
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 25-02-2012, 22:20
FRC #1700
Rookie Year: 2007
That's really cool! I assume the usage is too much to have a compressor that keeps up, or the weight of a compressor gives enough tanks to hold the air for one match. Can't wait to see you guys at BAE (and CT for that matter).
Unread 25-02-2012, 23:16
JackS's Avatar
Sideline Observer
no team (EWCP)
We're actually losing hood capability for BAE and CT. The hood was designed to make two pointers from the fender easier in case we weren't accurate enough at three pointers from the key. However, at the field we determined we are fairly accurate at threes, and the hood position had very little effect on how easy it is to make twos. By losing the hood, we can save almost 8 lbs for weight we can put down low. We like to tip a lot. :/
We don't have enough weight for the compressor and sufficient air storage. Also, We don't have the budget to purchase the new small compressor.
Colgate University
'16
Unread 26-02-2012, 00:34
PayneTrain's Avatar
AKA: Lizard King
Team Role: Mascot
I'm assuming your electronics are all stuffed around the conveyor underneath the Lexan. Widebots like that love to tip; we found it's best to move electronics as close as possible to try to at least get to a... teeter...
