Go to Post If you don't KNOW something as fact, please do not state it as fact. - dlavery [more]
Unread 24-02-2012, 22:55
farmersvilleRob's Avatar
farmersvilleRob farmersvilleRob is offline
FRC #4084
farmersvilleRob is infamous around these parts
Simple question?
If I cannot get my kinect to work with my laptop (drivers station) because of some really stupid stuff, and my autonomous code runs just fine without an initialization by the kinect, can I remove the kinect and have it run from the enabling? I'm 99% sure this will work because that is my only guess how other years worked. Once your in autonomous, it just executes. However, my question is- how do we get put into hybrid/autonomous? Do we just click autonomous in the driver's station?
If that's so, then I'm set. I just wanted to make sure
Unread 25-02-2012, 00:28
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Simple question?
When connected to the field network, the Driver Station takes its mode control from the Field Management System. Things will happen automatically during the match. The buttons for selecting things like autonomous and alliance station manually won't be active.
