Go to Post We were all rookies once, and we really have two ways to go about things: either take a page from the powerhouses and emulate their style, or complain about not having anything and risk falling into oblivion. - George A. [more]
Unread 25-02-2012, 21:09
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: A real puzzle - Electromechanical fault
Small spikes aren't a problem, I see a lot of brown outs that don't affect the radio or cRIO forcing them to reboot.
One toe below 4.5v and the protected outputs are gone though, and I've seen that happen from sharp spikes.
Monitoring the battery voltage ourselves in code has worked out when we have had a big draw device, such as a flywheel.
The FPGA code also monitors the battery voltage and reacts when it drops below a threshold voltage, disabling the PWM/Relay outputs.
P.S. I made a correction to my earlier statement, because I'd said that the PDP cuts the regular 12v outputs. It doesn't, but the effect is the same when the PWMs get disabled.
Attached is the circuit diagram.
Unread 25-02-2012, 22:54
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
FRC #0973 (Greybots)
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
While I'm sure you've checked this, it could always be a problem: could you be running the two CIMs in each CIMple box against eachother?
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 25-02-2012, 22:55
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
They are running 4 cims on 4 cimpleboxes... So I don't think that's the case.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
