Go to Post Pulling off an off season during a hurricane isn't easy. - Arefin Bari [more]
Unread 25-02-2012, 16:00
benjiengi benjiengi is offline
FRC #2134
benjiengi is an unknown quantity at this point
Catalyst controls help
I am using an xbox 360 wired controller that I can assign with a program I got but when I use it with Catalyst the control scheme does not work and it uses the preset for Catalyst. Does anybody know how to fix this or has run into this problem before?
Unread 27-02-2012, 14:37
FRC #2134
Re: Catalyst controls help
We figured it out. You sign into Catalyst as a keyboard then when you are playing you plug-in your controller and your assigned keys should work.
