Go to Post I shouldn't be doing a happy dance or anything, should I? - Qbranch [more]
Go Back   Chief Delphi > Technical > CAD
Unread 26-02-2012, 08:51
hardufy2 hardufy2 is offline
FRC #1574
hardufy2 is an unknown quantity at this point
fisher-price 13t pinion
what is the module of the 13 tooth pinion ? we get FP motor and it comes with a 13t pinion and i cant find any cad of this.
Unread 26-02-2012, 10:43
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Re: fisher-price 13t pinion
I believe it has a pitch of 32 teeth per inch of pitch diameter. To check, add 2 to the number of teeth (13+2=15) and divide by the outside diameter, in inches. You should get a number between 29 and 35.
This gear is not compatible with metric gears, which are the gears that typically use the module system. If you are looking for a source for gears that work with this one, the first stage of the black and orange gearboxes from the kit of parts should work, as should the first stage from any of the similar gearboxes from previous years.
If you can't find these gearboxes, have already used them, or just want metal gears, AndyMark has a good assortment of 32 diametral pitch gears. Unfortunately, this might take a while. Before you order, you should verify the pressure angle, it is either 14.4 or 20 degrees, Hopefully someone on here knows.
Unread 27-02-2012, 19:36
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
If you are using Solidworks you can just use Toolbox to create it.
