| I'd take a spoiler for you any day. |
CD Labview folks,
The Driver Station PWM display doesn't seem to work properly out of the box (base software). Last year I found this display to be very helpful in debugging. Has anyone figured out what the trick is to reenable this feature for 2012? |
Re: 2012 Driver Station PWM display doesn't work
There's a bug on the robot side.
It's defaulting to looking at the second Digital Module. Joe Ross pointed this out: http://firstforge.wpi.edu/sf/go/artf1439 Open up Build Dashboard Data.vi Look for the +1 feeding DIO Ref Open and remove it. |
And Just Like that, I got mine to Work Too!!!
CD,
THanks for chiming in, Mark. Will patch my local files to make it work. THanks also for posting graphic of solution, JChavis Last edited by marccenter : 26-02-2012 at 19:49. Reason: add info |
Having the same problem with the C++ side of things as well. Is the fix the same?
Nope, the C++ side has no built in Dashboard code. There is a Dashboard example that might help though.
If you open Robot Main, it is called on the right side of the main loop. Or you can open the Team Code folder in the project window and locate it there.
Greg McKaskle |
