Jaguar VBus Fault
Anyone experienced that before? Anyone know of a potential cause of that problem? I presume a short. Is it recoverable, or is the Jaguar dead?
Re: Jaguar VBus Fault
What's your battery voltage when idle? When under load? Usually the fault is a result of a stalled motor drawing too much current, or a low battery voltage to begin with.
It's just one Jaguar, other two are fine. The Jaguar has an over current protection that usually resets itself, but this was persistent for a full day.
What were you doing before and leading up to the fault? What diagnostics have been done to identify the fault? (i.e. how do you know its a vbus fault and not something else?) PWM or CAN? What kind of motor and mechanical load is being driven? Matt |
The diagnostics was done using the TI's Jaguar flasher. So it was daisy chained using CAN cables to the computer and the flashing software indicated a vbus fault. The motors were not driven by CAN, but by PWM. |
David,
A Vbus fault could be caused by a bad crimp, bad breaker or improperly terminated wiring in the PD. It is simply an indication that when you draw current, the voltage drops feeding the Jag. You might get the same fault with a motor that is drawing a lot of current but not enough to throw a high current trip. Check every inch of the wire between the PD and the Jag that is faulting looking for shorts, bad crimps, whiskers, loose hardware. Try spinning the motor by hand and see if there is a lot of resistance to your spin. It could be a bad motor, or improperly mounted motor on the transmission. If it is a drive motor, do you get the same results with the wheels off the floor? |
