Go to Post Stop making me want to spend money on books! I don't need any more good influences in my life!!!! - FourPenguins [more]
Unread 28-02-2012, 11:09
DavisC DavisC is offline
FRC #0539 (Titans)
Rookie Year: 2010
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Getting Started with the Accelerometer
Ok, so I understand how it is connected to the DSC but what is the cable that everyone is using?
Also, would the accelerometer be good for measuring speed and therefor distance?
And also is there a default program for the accelerometer somewhere in C++? Or is there a tutorial somewhere?
Thanks,
Davis
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 28-02-2012, 16:43
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Getting Started with the Accelerometer
We built our own cable, using a four-conductor-wide ribbon cable (colors blue, violet, grey, white) with female pins and four-wide housings from Hansen Hobbies.
Accelerometers aren't very good at giving speed data, and they're really bad at giving distance data, especially in a mechanically noisy environment like FRC robots.
I'm afraid the only examples and tutorials I'm familiar with are for LabVIEW.
Unread 28-02-2012, 19:24
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Accelerometer gives you accelerations. In order to obtain speed or distance data, you need to integrate the data against time to obtain speed (and double integration to obtain distance). Because of the fact that the accelerometer will pick up a lot of noise especially when the robot is moving, it means you will have major cumulative error in your integration. The error is especially bad for double integration. So beware if you decided to do this. We tried this a couple of years ago because we couldn't mount encoders on the wheels. We ended up using a lot of tricks to minimize the error. For example, disable the accelerometer until we need it, reset the accumulators right before we need to enable it, only use it for short runs, disable the accelerometer right after we reach target etc. Also, mount the accelerometer on shock absorbing material to minimize vibrations.
