Go to Post If you're doing it to win, you're doing it wrong. Teams who truly understand why they are doing what they do will win Chairman's simply as a result, an added benefit. The award isn't the goal. It's the impact you create, and the results you see. - dcarr [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 28-02-2012, 16:10
ProjectZero ProjectZero is offline
FRC #4276 (Vikings Robotics)
ProjectZero is an unknown quantity at this point
Help driving straight using PID and a Gyro.
Hi all,
Working on coding our robot to be able to drive straight using a gyroscope. The gyroscope initializes at the beginning of the map, getting it's initial heading. Now, I want the robot to at the press of a button be able to turn back to that orientation. I think I've finally structured the code below correctly. Questions:
1. Am I correct in assuming that when I enable PID in my DriveStraight command by writing enable(); that the robot will start doing what is written in the usePidOutput method?
2. What will the bounds of the "output" variable be? I know it's a finely tuned variable of the error between my gyro heading and my desired heading of 0, but I don't know if I can plug it into my motors or not.
I apologize in advance if there's a topic that answers this question. If that's the case, please just link me.Thanks in advance for your help.
SUBSYSTEM CODE
package edu.wpi.first.berserker.subsystems
import edu.wpi.first.wpilibj.command.PIDsubsystem;
public class DriveTrain extends PIDSubsystem (
private static final double Kp = 3;
private static final double Ki = .2;
private static final double Kd = .1;
private Robotdrive drive = new RobotDrive(Robotmap.leftMotor, Robotmap.rightmotor);
private Gyro newgyro = new Gyro(Robotmap.gyro);
private DriveTrain() {
super ("DriveTrain", Kp, Ki, Kd);
public void initDefaultCommand() {
setDefaultCommand(new DrivewithJoysticks());
protected double returnPID(){
return gyro.pidGet();
protected void usePIDOutput(double outpout) {
//Not certain what needs to go here.
COMMAND CODE
package edu.wpi.first.berserker.commands;
public class DriveStraight extends CommandBase (
double setPoint;
public DriveStraight(double setpoint) {
requires(drivetrain);
this.setpoint = setpoint;
protected void initialize() {
drivetrain.setSetpoint(setpoint);
drivetrain.enable();
protected void execute() {
protected boolean isFinished() {
return Math.abs(drivetrain.getPosition() - setpoint <.02);
protected void end() {
drivetrain.disable();
protected void interrupted() {
