Go to Post Although I don't agree with the ref's call...we accept it because a ref's call is a final call. - David Guzman [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 23:04
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Lock it in and go!!!
Posted by nuts4first.
Engineer on team #340, GRR - Greater Rochester Robotics, from Churchville-Chili and Nortel Networks.
Posted on 2/7/2000 8:38 PM MST
We just finished testing our drive system and this works....
If you are looking for a quick and easy way to lock your drill gearbox in low or high gear try some O-rings. You'll need 2 per motor to get the correct width. They go in between the gears in the back half of the motor assembly case. I think we used 1-1/2 OD 1/8' wall.
Good luck. If you try it, let me know how you do with it.
-Team 340
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
