Go to Post Andymark has everything! - nighterfighter [more]
Unread 29-02-2012, 11:51
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
pic: Inventor Render - Cyber Blue 234 - MANiMal
Unread 29-02-2012, 12:00
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Re: pic: Inventor Render - Cyber Blue 234 - MANiMal
I don't know Chris, looks like something is missing from this CAD model.
Regardless, it is another great Cyber Blue 'bot, and I can't wait to see it in person (if I get the chance). I like the 3 independently controlled ball elevator system.
A few questions:
Where is the camera?
Is the cRIO unprotected? or is the shielding left out of this render?
What does the transmission look like?
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 29-02-2012, 12:04
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Nice work. What does the window motor in the upper right of the photo do?
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 29-02-2012, 12:05
tim-tim's Avatar
AKA: Tim Miedzinski
I assumed that it is a motor to control the hood on the shooter. Thus allowing an articulating trajectory for their shots
The RoboBees
Unread 29-02-2012, 12:27
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
I guess I'll be seeing it in person very shortly. Sweet.
On your 8 wheel drive - what offset do you use for the heights of the wheels relative to each other? I have to make an adjustment to our 6-wheel drive when we get there - too much drag on the outer wheels - and I used the stock offset dimension from the kitbot frame which is .15.
Close enough to taste it, too far to reach it
Unread 29-02-2012, 12:34
tim-tim's Avatar
AKA: Tim Miedzinski
We (FRC 401) use an offset of 1/8" with 6" 6 wheel drive. This is also using the new "high grip" wheels from this year's KoP
It does appear that this is a wide robot, meaning the wheels don't have to be offset for the wheelbase vs track width ratio
The RoboBees
Unread 29-02-2012, 12:52
Thats a good guess, and where I would start as well. However, I didn't see an obvious connection point/completed mechanism thus my question to 234s designers.
-Brando
Unread 29-02-2012, 22:49
Rookie Year: 1942
Still a few things missing - but
8 wheel drive, all at same level. We found no drop needed with the wide chassis.
Window motor at top drives a worm screw to move the shooter body for alignment to the goals.
The camera is mounted on top, in this view it is hidden by the top of the shooter curves.
Protective lexan with logos is removed.
AM SuperShifters. Large sprockets to get the wheel speeds we wanted.
Still a work in progress to get the rest of the systems installed.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 29-02-2012, 23:02
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
Rookie Year: 2011
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Judging by the roller visible on the back side of the robot, I'm guessing it has multiple side pickup?
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 01-03-2012, 00:22
Rookie Year: 1942
pick up front and back, moving the balls into the center staged elevator.
sensors keep count of the balls in the elevator and will reverse the front and rear collector rollers after 3 are staged to help prevent getting a 4th.
Chris Fultz
