Go to Post Experience...you can't buy it, you might be able to get some for free by reading CD a lot, but usually you have to earn it, and it's not always fun. - MrForbes [more]
Unread 01-03-2012, 18:35
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
Ball deflectors.....don't
1st week regional and lots of field com problems as usual. However, the biggest problem we've seen on the real field is that the ball deflectors do a terrible job of keeping the balls out from under the bridge, and if it's on the far side you can't even see it's there. Lots of teams unable to drop the bridge because there is a ball stuck under it.
Close enough to taste it, too far to reach it
Unread 01-03-2012, 18:44
alectronic alectronic is offline
no team (Volunteer)
Rookie Year: 2007
alectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant future
Re: Ball deflectors.....don't
i was noticing that too from what i could see online. it seems like the actual balancing isnt too bad if you have don't try too last second. but if the balls are stuck there, then it doesn't even matter. it will be interesting to see if there is a design update for week 2.
Unread 01-03-2012, 21:53
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
Im glad we add a second camera. I hope the figure out a way to fix this.
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 01-03-2012, 21:56
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
This was noted during many pre-ship date scrimmages. FIRST's response, IIRC, was that this was intended and is an added challenge.
Unread 01-03-2012, 22:25
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Rookie Year: 2007
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
further proof as to why going over the bump is necessary
but seriously, i would advise teams to cross the barrier and approach the bridges from the side closer to their alliance stations. You can see if there are balls under that side and your tipping the bridge down should dislodge any balls on the far side of the bridge. If there are balls under your side of the bridge then approach from the far side... if there are balls under both... then i'm not sure what you do :/
rock the bridge?
Unread 01-03-2012, 22:54
Bob Steele's Avatar
Bob Steele Bob Steele is offline
Professional Steamacrit Hunter
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
I wonder what is going to happen when an alliance rolls balls under both sides of the opposing alliance bridge..so they cannot balance it.
I wonder if this will be a G25 violation? It should count as an interference with the act of balancing... if that is the case... it will be a difficult call for a referee to make if it is done ... it is a huge penalty... technical foul AND the balance score...
It would be easy to call if it were done obviously but I can see balls being chased and getting stuck... who is to say it was intentional?
I wish the deflectors worked better..
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 01-03-2012, 23:02
Andrew Lawrence
Posts: n/a
I know it's supposed to be part of the "challenge", but I don't think it'd be fair to see any teams loose a match only because their bridge was blocked by two of balls.
Unread 01-03-2012, 23:49
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Its a G14 violation:
Originally Posted by G14
Strategies that use Basketballs to either aid or inhibit Balancing of any Bridge are not allowed.
Violation: Technical-Foul, and counting or discounting the affected Bridge as Balanced, as appropriate.
Unread 02-03-2012, 00:21
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
I think the question was if the balls were placed there inadvertently, but by the actions of an alliance.
I find it somewhat disturbing that this problem is being considered part of the challenge, when they went to specific lengths to assure us it wouldn't.
Unread 02-03-2012, 00:38
kjohnson's Avatar
AKA: Kyle J.
FRC #1610 (BOT)
From the video: "Its there to help balls roll out from under the bridge."
I haven't seen or heard anywhere where FIRST has specifically said that balls wouldn't get stuck under the bridge. As seen in the video, the polycarb sheet lifts on one side when the other side of the bridge is pushed down. The weight of the bridge has to be removed from the top of the ball before it will roll out. From the field demo video that you linked, it looks to me like the bridge and polycarb sheet are behaving just as FIRST expected.
Unread 02-03-2012, 00:49
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
The field is working as designed, from my point of view that design was not clearly stated. Since the ball ramps aren't part of the low cost field there was a slim chance a team would discover this challenge on their own with out some hints from FIRST. They could have worded it "that the ball ramps allow balls to be removed when the bridge is tipped to the other side" and I think a lot more teams would have understood the challenge as FIRST intended it.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 02-03-2012, 01:10
BigJ BigJ is offline
AKA: Josh P.
FRC #1675 (Ultimate Protection Squad)
Rookie Year: 2007
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
I think the "it wasn't on the low cost field!" argument was covered last week with 118's hanger.
I dunno. I feel like the issue would come up in design when discussing bridge interactions. "Would I ever want to pick the bridge up? What are the reasons?" etc.
Unread 02-03-2012, 01:36
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
The problem here is that, even if that was clear, a scenario still exists where a ball can get stuck under either side, making it impossible to lift up and clear*.
Whether it's intentional or not, the fact of the matter is that it was represented to teams that a system was in place to keep balls from getting stuck under the bridges, and balls are still getting stuck under the bridges. I have yet to see any robots which can get on the bridge without lowering it or without the assistance of another robot**.
When you have something as basic to the game as a Coopertition bridge, which counts as a win, it should be doable by almost every team...but if balls get jammed, nobody's getting on that Coopertition bridge.
There are some things the GDC can rightfully say are "part of the challenge", such as the chains sometimes deflecting goals in 2006 and 2010, or popped tubes in 2007 and 2011. This should not be one of those, as it is a situation which prevents teams from being able to complete a major part of the game, by no fault of their own, and is happening it a large number of the matches.
*I have not played with a real bridge with balls stuck under it. It's possible that they will move enough that rocking the bridge will clear them, even though it can't be pushed down far enough to climb on to
**With the exception of 118's hanger mechanism, pending legality rulings. It's worth noting that 179 can hang from the bridge without climbing on it, but someone needs to get on it first for them to be able to balance by hanging, thus they would require the assistance of another robot (and another robot requires theirs).
Unread 02-03-2012, 02:13
savage's Avatar
savage savage is offline
FireFighter Paramedic
AKA: Ben White
FRC #1368
savage will become famous soon enough
Send a message via AIM to savage
Yes it is a T foul and we will be on the look out for this.
  #15   Spotlight this post!
Unread 01-03-2012, 23:35
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
rock the bridge?
you make a collector that can fit under the bridge to pull them out
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
